Old 10-18-2005, 01:08 PM   #1
67 cst swb
67 cst swb's Avatar
6-lug Conversion Rotors Question?
Does anyone have a 6-lug conversion rotor they could look at? I'm wondering if there is a "CASTING #" anywhere on these rotors. If anyone could help out it would be greatly appreciated.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 10-18-2005, 01:36 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 6-lug Conversion Rotors Question?
I have a set of Early Classic 6 lug rotors at home in my shed. I'll look, but all I remember is the "minimum thickness" cast into them. ECE disguised them well if they are an OEM rotor. They came in unmarked boxes.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-18-2005, 02:40 PM   #3
dennislbrooks
dennislbrooks's Avatar
mine came just like Tx Firefighters --someone is casting them for some OEM somewhere in the world.
dennislbrooks is offline   Reply With Quote
Old 10-18-2005, 02:50 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I ain't no help, either. They came in a box, and they went on the truck. 5-lug GM rotors are a direct replacement, if I ever decide to go with that pattern option.
Member Nr. 2770
Old 10-18-2005, 03:09 PM   #5
67 cst swb
67 cst swb's Avatar
I'm hoping to get a casting # directly off the rotor itself... I deal with 2 mojor brake suppliers. I was told all rotors and drums all have a number cast into them for the cast molding. With that #, the part can be interchanged to my suppliers #. Thanks guys for your quick response.
Tx; I'm eager to hear from you.
Bryan
My Trucks:
Old 10-18-2005, 04:00 PM   #6
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
That is true for most OEM or aftermarket OEM parts. (Key being OEM) The 6 lug rotors for the disk brake conversions are for custom aplications and are usualy made by the company that manufactures the conversion spindles most of witch do not use casting numbers. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-21-2005, 06:20 AM   #7
Tx Firefighter
The casting number on the rotors is "6069"
Old 10-21-2005, 10:25 AM   #8
FirstGen
Just Don't Stop!
FirstGen's Avatar
You should try the 1990 2x4 3/4 ton light duty rotors, they are 6 lug and have the same measurements as the early disc setups. That's what I am running but with the 1990 spindle also...
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 10-21-2005, 04:07 PM   #9
67 cst swb
67 cst swb's Avatar
FisrtGen,
I already tried them everything was correct except the alignment... the rotor surface centerline was too far outboard in relation to the caliper... I was kinda excited until it came to putting it on my truck.... My cost was like $35.00 or so each... Oh Well..
My Trucks:
Old 10-21-2005, 04:28 PM   #10
FirstGen
Just Don't Stop!
FirstGen's Avatar
Originally Posted by 67 cst swb
FisrtGen,
bummer. I'm running the 1990 spindle, caliper and rotors so it worked for me. I just wanted to have a 6 lug with off the shelf parts...
Good luck with it.
TT LSA/6L90e/9"
Old 10-25-2005, 11:56 AM   #11
67 cst swb
67 cst swb's Avatar
FirstGen,
I may have been incorrect on that. I got a reply today from My brake suppplier. Let me do some research, I'll let you know....
I'll keep you posted guys...
My Trucks:
Old 10-31-2005, 10:49 AM   #12
67 cst swb
67 cst swb's Avatar
FirstGen,
Well Damn... looks like the second try was the same results as the first. So, I'll be looking into the complete spindle thing like you did... I'm interested in evertything that you needed. Do you remember? Do you just use the 88-92 ball joints on the 71-86 control arms? Then use the 88-92 outer tie rod end? or something different? PM if you'd like... Any help would be greatly appreciated.
My Trucks:
Old 10-31-2005, 10:55 AM   #13
Custom 68
Custom 68's Avatar
did you check GMC Pauls, I know he has the kit but I thought he has the rotors for replacement also...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-31-2005, 11:21 AM   #14
FirstGen
Just Don't Stop!
FirstGen's Avatar
I used the 88-98 ball joints on the stock 1/2 ton 67-72 upper control arm and then had to use a 3/4 TON 67-72 lower a-arms to make up for the difference in the spindle. Then I used a different outer tie rod which I will have to look up the number for...
-Taylor
TT LSA/6L90e/9"
Old 10-31-2005, 12:00 PM   #15
stllookn
Saving 1 truck at a time!
stllookn's Avatar
FirstGen, Can you post all the info here so the rest of us can benefit from this conversion. Did you stock or drop spindles? That sounds like it might be a lower cost conversion than going with a new conversion kit.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-31-2005, 12:17 PM   #16
FirstGen
Just Don't Stop!
FirstGen's Avatar
Sure can. I have already posted this entire conversion about 3 times. At one time it was saved in the FAQ pages but I don't know if they are there anymore.
anyway, I have drop spindles and bags now but origionally I used stock height spindles.
TT LSA/6L90e/9"
Old 10-31-2005, 12:40 PM   #17
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have a pair of spindles off of my sons' '96 GMC Sportside, left over after installing dropped spindles. If anyone wants them, just pay the shipping. The truck had less than 60K miles when these came off of it....in summer of '02.
There would be a packaging charge, too. But, no charge for the spindles to anyone who wants them.
Member Nr. 2770
Old 10-31-2005, 01:52 PM   #18
FirstGen
Just Don't Stop!
FirstGen's Avatar
You'll have to make sure that those spindles had the 1.25" rotors not the 1" rotors which most of them had. The 1.25" rotor style are off the early 88-91 3/4 ton light duty 2x4... there are other year and makes but I don't remember off hand.
TT LSA/6L90e/9"
Old 10-31-2005, 02:20 PM   #19
67 cst swb
67 cst swb's Avatar
FirstGen,
Thanks for all your helpful info... It's people like you that make me come to this web-site time after time... Thank You soooooo much....
I can't wait for your parts list...
My Trucks:
Old 10-31-2005, 04:01 PM   #20
70GMCer
70GMCer's Avatar
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-31-2005, 08:36 PM   #21
67pete
ChevLoRay, I'll take those spindles off your hands, if the packing and shipping to 25271 isn't too much.
67pete is offline   Reply With Quote
Old 11-01-2005, 12:09 PM   #22
67 cst swb
67 cst swb's Avatar
ttt
My Trucks:
Old 11-01-2005, 12:13 PM   #23
stllookn
stllookn's Avatar
FirstGen, I too looked through every page of the FAQ section and could not find it. Oh well. I am not converting mine yet...still priming the body parts. I will get to disc brakes long after the paint is done.
Old 11-02-2005, 07:18 AM   #24
Tx Firefighter
ttt
Didn't you see my post above with the casting number? It's cast right into my ECE 6 lug rotors. Is that not what you were looking for?
Old 11-02-2005, 11:48 AM   #25
FirstGen
Just Don't Stop!
FirstGen's Avatar
ttt
Well I dug out the part numbers. This is what I bought for this swap:
FROM O'REILLY AUTO PARTS:
2 MOOG ES2020RTL - inner stock 68 style tie rods 23.99 each
2 MOOG ES2836RL - outer conversion type tie rods 35.99 each
2 ADC K6293 - Stock 1990 lower ball joints 29.99 each
2 Stock upper 1990 upper ball joints I used the ones on the spindle I bought
FROM AUTOZONE:
2 BRAKE ROTOR #043398 also 5572 or 572 at 59.99 each
I also bought the wheel bearings but you can just look that up there.
Basically, I bought a 1990 model truck from K-member for like a $100. I used the spindles, calipers, brake lines, bearings, upper and lower ball joints, and factory rotors. You will also need a pair of 3/4 ton LOWER a-arm off a 1968-1972 chevy truck (C20). The only special piece in the combo is the OUTER tie rod as I have listed above from MOOG. The inner one is a stock 1968 chevy truck tie rod. It's possible that I have the two tie rod part numbers backwards but I remember the one off tie rod being more expensive than the stock one.
You will also now need the 14mm lug nuts for the front. I went ahead a re-drilled my rear axles to take the same studs since the factory studs look weak as hell.
-Taylor
TT LSA/6L90e/9"
