Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-19-2005, 09:17 AM   #1
bisquik65
bisquik65's Avatar
Dont use a droplight when working on a fuel tank!!
You know these lights allways fall on the ground and the bulb pops!!!Now with fuel vapors in the air from a newer car or truck with fuel pump in tank....(thats why i like old trucks) you have gas everywhere and when the light falls as you get out from under the car/truck....It is instant explosion and fire !!!!! Whatever you do,make sure you do not do this!!!
2 shops were burnt to the ground ,including one chevy dealer shop....because of this...Its not good when you loose your ride,tools,shop,and mabye get hurt really bad...
This has not happened to me,just found out from friends....Erick
bisquik65 is offline   Reply With Quote
Old 10-19-2005, 09:20 AM   #2
Joe67
67 is sold
Re: Dont use a droplight when working on a fuel tank!!
Why would there be more vapors from newer trucks then older trucks?
An open fuel system is an open fuel system...
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-19-2005, 02:04 PM   #3
cdowns
cdowns's Avatar
if you spend the money for a good explosionproff drop light there won't be a problem// the $4.99 homedepot ones are dangerous even not around gastanks
Old 10-19-2005, 04:05 PM   #4
bisquik65
bisquik65's Avatar
What i was getting at is you don't have to work on the fuel tank in a old truck that often.. .And 67-72 tanks inside the cabs dont rust ...to bad...
I try and fix them outside when i can...
Your right,all tanks put off vapors....
Old 10-19-2005, 05:09 PM   #5
Joe67
67 is sold
Gotcha
Old 10-23-2005, 10:34 PM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I have thought of this,and I do a lot of fuel pumps replacements too
I had a guy swap his fuel pump in his S10 a few days ago.I went to town,and came back to find him sitting there beside an open tank,with the sending unit in his hand,removing the fuel pump.WITH A CIGARETTE IN HIS MOUTH!
I took that thing away from him,and put the pump together,back in the tank,and told him to go smoke,and then come over and finish up.I mean I was nice enough to loan him the tools,and place to work,he couild have used some sense
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-11-2005, 09:53 AM   #7
gizmo
100% Beefcake
gizmo's Avatar
Don't use a vacuum cleaner to remove the dirt away from the sending unit before you remove it either. I found out the hard way. It sucked the gas fumes out of the tank and the vacuum cleaner went KABOOM! It blew into five different pieces and flew twentyfive feet in the air. I put the vacuum cleaner back together and put it back in the wifes closet without saying anything. The next time the wife used it she thanked me for fixing it. She said it works twice as powerful now.
1969 C10,350,4:11 posi, Fast Enough
1984 Monte Carlo SS
1987 Chevy S-10, 355 w/150 Shot of Nitrous, Fun,Fun
1938 Nash Lafayette
1956 MG Magnette
gizmo is offline   Reply With Quote
Old 11-11-2005, 05:06 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's one reason so many guys are using flourescent drop lights nowdays. They don't shatter when dropped like an incadescent bulb does.
They also don't get hot enough to burn you if they fall onto skin or scorch upholstery either.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-13-2005, 08:02 AM   #9
LONGHAIR
Yeah^^^^ burn yourself while upside-down under a dash.........and you will switch to flourescent, and never go back.
LONGHAIR is offline   Reply With Quote
Old 11-29-2005, 06:15 PM   #10
Moostifer
a fool with no money
Moostifer's Avatar
that's the funniest thing I've read in a long time!
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 11-30-2005, 09:56 AM   #11
bisquik65
bisquik65's Avatar
That would be funny to see on video.... Hey someone e-mail mythbusters and get them to do it.... so all of us can see it...
Old 12-21-2005, 01:09 PM   #12
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
I've never used one always using the ole trusty maglight....Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 12-24-2005, 10:42 PM   #13
BigMike
BigMike's Avatar
Guys, I've had it happen to me before. About 17+ years ago I was helping my brother change out the fuel filter in his VW bug. It was located under the rear of the bug where the fuel line transfers from the pan (chassis) to the engine compartment. I had a drop light hanging from one of the holes in the underside of the rear fender and was changing the filter (drivers side rear wheel was off). Well there was gas everywhere, I had pinched off the line from the tank with my small vise grips, but the fuel emptied out of the carb rather quickly. I was getting up to get the new filter when I bumpted the light. It fumbed around for a few seconds as I tried to grab it before it hit...WHOOOSH! I was lucky to have gotten up quickly when it hit (I had gas all the way down my arm). My brother went flying into the back yard to get a hose as I am trying to push it the rest of the way out of my garage (attached garage).
He got the fire out immediately and we both caught our breath, it could have been much worse. I no longer use drop lights anywhere near fuel anymore
I have another long fuel burning story (kinda funny), but that is for another day.
Mike
BigMike is offline   Reply With Quote
Old 02-03-2006, 01:21 PM   #14
77C15
77C15's Avatar
This is what happens when someone next door drops a light into fuel on the floor. I was lucky, most of my parts were stored outside in a trailer.
77C15 is offline   Reply With Quote
