10-19-2005, 09:15 PM | #1 |
Junior Member
steering column / shaft question
What determined the use of the separate intermediate steering shaft vs the one piece column and shaft that I found on my '67? I bought a tilt for it but now see that I will have to find a lower shaft to go with it. What shaft do I need to look for when using a converted van tilt in my '67?
Scott
'67 SWB big block project '85 C60 school bus motorhome conversion |
10-19-2005, 09:32 PM | #2 |
Vortec in the works
Re: steering column / shaft question
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
Check out this link, it has all the info you need
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
10-19-2005, 10:08 PM | #3 |
Junior Member
Thanks, I had read that before but it only talks about collapsing the shaft, not application stuff. I assume some trucks came with a separate lower shaft. I bought a truck non-tilt auto column from a board member that was two piece and he included a lower shaft. What trucks used one piece column /shafts and what used two piece is my question.
Scott
10-19-2005, 10:13 PM | #4 |
there are a few differnt years that had the part your looking for, some on newer trucks than ours, but some the splines are different, so make sure you get the right one,,,There's several differnt types out there.
I got a bench seat baby, you don't have to sit over there. |
