A BUDDY OF MINE HASAN OD69 ROTTING IN HIS FIELD. WELL HE SAID I CAN HAVE NYTHING BUT THE BED. MY QUESTION IS DO YOU THINK THE HEADS WOULD BE WORTH PULLING OFF AND HAVING REWORKED. IT HAS A 327 AND EVEN THOUGH THE CARB IS MISSING I COULD SE A 4BARREL INTAKE UNDER THE RATS NEST. HOW MUCH DO YOU THINK THE WORK WOULD RUN? OH SORRY I HAVE A PRETTY MUCH STOCK 35O GETTING READY TO PUT ON AN EDELBROCK MANIFOLD AND HEADERS SO I FIGURED WHY NOT DO HEADS TOO.
------------------ 72 CHEYENNE 3/4 TON 4X4...14 bolt full float rear.4.10 gear and 350/350/np205 has a little needs a lot!
72 CHEYENNE 3/4 TON 4X4...14 bolt full float rear.4.10 gear and 350/350/np205 has a little needs a lot! |
Recovering Truck Driver
I'd hook onto it and drag the whole truck to your place!! Check the casting #s on the heads, does it have any bolt holes in the fronts of them?? They may be well worth saving.
------------------ Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84 ralleys and 31/10.5s Angel girl: 67 Cutlass convertible 330, 3spd stick Greener: 90 GMC Jimmy 350/auto Chad Stephens Orleans,NE no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
its all about the +6 inches
I'd snag the whole engine.
The casting numbers for the head can be found between the rockers. Just pop off the cover and get the numbers off of it, some oen will be able to decode. My book is way off, so I can't help normally. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
