Old 10-20-2005, 10:20 PM   #26
kwmech
Re: Ever seen a Ramhorn like this?
Good grief --- weatherhead part number--- 131x5--- they are about a buck a piece.
kwmech is online now   Reply With Quote
Old 10-20-2005, 10:34 PM   #27
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Thanks!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-20-2005, 10:38 PM   #28
kwmech
Take the manifold with you to the parts store---if its anything like the store I go to, the people that put the parts away never get them in the right drawer. It's always messed up.
Old 10-21-2005, 02:06 AM   #29
magic402
the actual answer to your thread pitch is a hydraulic thread called an o-ring fitting. It's been a while but I think the aeroquip plug # is 2660-5 or 2662-5 , it's a #5 thread. It's close to the 5/16 flare and 3/8 npt but its not the same hence tight threads. you'll have to go to a hydraulic shop to get these.
magic402 is offline   Reply With Quote
Old 10-21-2005, 09:47 AM   #30
kwmech
Wrong---guess again. Why would the factory use a hydraulic fitting for a smog pump tube.
Old 10-21-2005, 01:29 PM   #31
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I just use brass NPT pipe plugs. I screw them in as tight as any sane person would and go on with life. Yes, the threads are slightly different, but they don't leak and it's not like I'm ever going to remove them and reinstall the smog tubes.
I don't torque anything tight enough to actually break the casting though.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
