Old 10-23-2005, 03:11 PM   #1
ejkh87
Shaving Drip Rails
Hello all. I am doing the bodywork on my 69 c10 now and I was wanting to shave the drip rail. Is this hard to do, or is it fairly easy.I know i need to fill the gap with weld, but I dont know if it needs a panel.
ejkh87 is offline   Reply With Quote
Old 10-23-2005, 03:17 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Shaving Drip Rails
It's been discussed, basically it's a pain to do right because the drip rail was GM's easy way out of making two or three pieces of metal meet. IIRC if you mess it up you'll ruin the cab. May want to get a junker to practice on.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 10-23-2005, 03:39 PM   #3
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Three pieces of metal meet in the driprail, cut about 1 in. or so and weld at the time, if you cut more before welding you'll run the risk of the panels not lining up when you weld everything back up.
Since you asked this question it seems like it should be better you leave this to a pro before you wind up with a junk cab or as mentioned above get a junk cab to practice on
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 10-23-2005, 04:52 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
I did it on a 60-66 no problem, but I read an article about shaving 67-72's and there's a lot more involved to make it look right. I'll see if I can dig up the article.
Frizzle Fry is offline   Reply With Quote
Old 10-23-2005, 09:47 PM   #5
pat
pat's Avatar
I dont think its as bad as everyone says, I did mine this summer without ever doing any previous body repair/welding. I didnt do the full on shave, just cut the lip off and smoothed it. Just go slow and cut small portions off. A reciprocating saw saw really helps so u dont have to grind as much.
pat is offline   Reply With Quote
Old 10-23-2005, 09:49 PM   #6
purple gas
I thik Iread the same article,, It looks pretty involved and I'm glad I read it or I'd likely have tried it and ruined my cab.. There's a lot of ways you could screw it up,, be careful
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 10-23-2005, 10:17 PM   #7
shifty
Questionable
shifty's Avatar
Use the search feature at the top of the forum. There are some really kickass posts from days past on this topic - including what kind of filler to use and some caution - from what I remember reading, this is not that easy - when you cut the drop rail, I think there is significant work to get the two pieces to marry up again.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-24-2005, 12:24 AM   #8
pat
pat's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=118119
http://67-72chevytrucks.com/vboard/s...d.php?t=123612
