Hey guys, I just spent the afternoon trying to use 6 cylinder engine towers to mount a 350 vortec motor in my 70 c 10 chassis. Once, I stopped and thought about what I was trying to do I just shook my head in shame.
![]() I need suggestions for v 8 mounting engine towers, I have the old stye 3 bolt rubber pads already on the 350 (new old style mounts not the original dry rotted). Do any of the vendors repop v 8 towers? Towers are the steel part that attaches to the rubber engine mounts and to the rails of the truck. Any suggestions and part numbers appreciated.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
Re: this just in from the "i feel stupid" files
i have a pair of good used ones $35.00 shipped to you. bill
The LuvShack Garage
So exactly how many hours did you spend trying this
![]() . . . . . . . . . . . . . . . . . . . . . . J/K with ya, I would have lost it trying to figure it out ![]()
Needs a Big Block
you should have still been able to bolt in the motor using the 6 cyl stand the motor will be Lower I think. unless they are from a 292.
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
billsbowtie, pm sent
2 hours of lost time if they can be made work please let me know
User #12137
![]() Join Date: Apr 2004
i got a 327 bolted to the 6 banger stands all it did was move the motor back
wait i cant remember what mounts are on the motor ![]() ![]() |
![]() ![]() Join Date: Jan 2005
What kind of transmission do you have?
I have a late model 5 speed that was behind a 4.3 in a s-10.
i think that my shifter is going to be real close to my seat or I may possibly have to have buckets due to the shifer being on the back end of the tranny. but what does that have to do with this thread?
Vortec in the works
I used the 6 banger stands on mine also, 98 vortec and used 68 327 mounts on motor and a turbo 400 trans mount on the 4l60
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
#10 | |
Questionable
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
The location of your engine stands is going to affect where your transmission crossmember needs to be mounted. The inline 6 stands mount farther back than the V8 stands. Considering that your shifter is so far back, it sounds like you would be better off moving the engine forward on V8 stands.
Still drivin' a Rat Rod
I thought the stands were the same,just the location was different.Am I wrong on this?
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website Last edited by Brainchild; 10-23-2005 at 10:53 PM. |
The stands are different. The V8 stands have a curve to them when viewed from above, but the I6 stands are straight.
Yeah,they`re different.The V6 will sit lower on the I6 towers.It`s best to mount the V8 forward in it`s intended position.The fan and shroud will be correct and you`ll have more room for distributor,especially HEI.
#15 |
thanks for all the replies,
i have been trying to mount in the v 8 position so i could get the shifter as far forward as possible. i may have to have a "c" shaped shifter formed to have a middle part of a seat or i may have to have 2 buckets only looking like the shifter will be about nine inches back from the front cab mount.
#16 |
Seems like there is 3 1/2-3/4" diff in the two positions if I recall, the six stands will not work in the front holes. Brian
