Old 10-18-2005, 09:31 AM   #1
shelby987
shelby987's Avatar
35" tires on 3/4 ton 4wd
I am toying with the idea of putting some BFG mud tires on my newly purchased 70 3/4t 4x4 and wanted to know how much of a lift I needed. I have a good set of stock general purpose tires on there now, and like the stance, and would like to keep the lift to a minimum so I can put those on some steel wheels when I am done, and keep the road usage of the 35" to a minimum.....any thoughts 2", 4", stock?
shelby987 is offline   Reply With Quote
Old 10-18-2005, 09:38 AM   #2
Yukon Jack
Yukon Jack's Avatar
Re: 35" tires on 3/4 ton 4wd
Here is a pic of my 69 K20 when I had a 4" lift on it with 35x12.50x16 Super Swampers on it. No rubbing just driving around on the road, but I'm sure it would have rubbed off-road if you crossed the truck up.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-18-2005, 09:46 AM   #3
Dean
Dean's Avatar
I have the 4" Skyjacker lift on both of my K20s with 35" BFG. No rubbing on street but I'm sure it would on the front lower fender corner off road.
Dean is offline   Reply With Quote
Old 10-18-2005, 09:50 AM   #4
shelby987
shelby987's Avatar
do you think 33's would be a problem off road without a lift? would a 2" lift be enough, or am I looking at a 4" either way I go? just trying to figure out where I can save $$$ at the moment, and still get the rig onto the road and into the mud pit!!
that pic. is not helping the fact that I can't pick up the truck until wednesday night!
Old 10-18-2005, 11:12 AM   #5
Yukon Jack
Yukon Jack's Avatar
I know I have read of some people running 33"s with no lift. If it is fine on the road, it might be alright in a straight mud pit. Hopefully someone with real knowledge will jump in to help on that question.
Old 10-18-2005, 04:09 PM   #6
FUNMUDDER
FUNMUDDER's Avatar
You can run 285/75s (around 33s) on a stock truck with no rubbing, maybe a little off-road. But if you want added clearence for 33s, get 2inch add-a-leafs from jc whitney. Be right around 100 bucks all 4 corners, IMO. It would also add more strength to the rear suspension if your going to work this truck at all. Get your POWER STEERING first, though.
FUNMUDDER is offline   Reply With Quote
Old 10-19-2005, 03:10 PM   #7
Beast388
Suburbans RULE!
Beast388's Avatar
I have a 4" with 35's and I rub when I get really twisted up off road. I have trimmed the fenders a bit, but I think I need more cutting.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 10-19-2005, 04:26 PM   #8
FUNMUDDER
FUNMUDDER's Avatar
That thing is a BEAST!!!!!!! AWESOME!!!
Old 10-19-2005, 04:53 PM   #9
Beast388
Suburbans RULE!
Beast388's Avatar
Thanks!!
--Ben
71 GMC Suburban 4X4
The "Beast"
Old 10-20-2005, 07:30 PM   #10
b454rat
I like the terrain, too!!!!
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 10-25-2005, 10:01 PM   #11
al's71gmc
4 eyed fever
al's71gmc's Avatar
For offroad use I'd go with 4" for 33's and 6" for 35's. That should be plenty without trimming, for anything but extreme use.
Al
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 10-26-2005, 01:44 AM   #12
4x4Poet
Great action shots, Beast. Looks like you were showin' the Jeepers how to run mud.
Great truck, too.
Where on the tires have you experienced crossed up tire rubbing? The tread, or the sidewall, or both?
I think I can see where you trimmed the front fender cups. Where else have you trimmed? The mud obscures my vision.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 10-26-2005, 11:07 AM   #13
Beast388
Suburbans RULE!
Beast388's Avatar
Great truck, too.
Thanks for the compliments!
I typically rub the "corner" of the tire, where the tread meets the sidewall. That part of the tire contacts the edge of the wheel opening where the inner and outer fenders bolt together.
So far, I have only trimmed the front "fangs" or fender cups as you called them. Some trimming at the rear of the opening is in order.
Did you say mud? I didn't quite conquer this one.
--Ben
71 GMC Suburban 4X4
The "Beast"
Old 10-26-2005, 01:26 PM   #14
Chris_T
I have 6" front, 8" rear skyjacker springs with 35's on my Blazer and I will occassionally bite the rear of the front wheelwell and the front of the rear wheelwell. I've cut the "fang" on the front, but that's it. 99% of the time it is fine - it's only when I get the axles crossed up that it becomes an issue.
Chris_T is offline   Reply With Quote
Old 10-26-2005, 07:54 PM   #15
1967k30
1967k30's Avatar
Anyone have pic's of 6" w/ 37"s? I have 4" springs and I'm going to use some 2" shackles but I'm thinking 35"s will be too small.I had 33"s on it and they looked really small so they went on my D-Max and I'm trying to decide weather to run 35" or 37"s.It's my wheelin' truck so I don't need em' rubing.
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 10-28-2005, 06:17 PM   #16
CyberRanger
CyberRanger's Avatar
You can run 35" tires if you stay w/ a narrower width tire & zero offset. I'm running 36x11.50s (305/85R16) Buckshot Mudders on late model stock steel rims & have trimmed 3" off the lower front fender corners. I have a buddy in our 4x4 club who runs 36x14.50s Swampers & has to run 8" of lift to clear them offroad. The only rubbing I get is when I'm seriously crossed up--get a tiny bit at the lower front edge of the rear fender.
'71 K20 Custom Deluxe - 1 owner - Original 350 & 4 spd, Rams horn dual exhaust, Centerforce clutch, K&N 4"x15", factory tow hooks, 4" Skyjacker Softride, Rancho RSX9000s, custom Firestone AirRide overloads, 36" 305/85R16 10ply Buckshot Mudders, 4.11 gears
CyberRanger is offline   Reply With Quote
Old 10-28-2005, 11:01 PM   #17
breeh
Recovering 67-72 Addict
breeh's Avatar
Here is a pic of my 33's with 4" of lift. I have never had any clearance issues. I have been considering 35's as well but I am concerned about the rubbing.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
