Old 10-25-2005, 07:00 PM   #1
FUNMUDDER
FUNMUDDER's Avatar
Question Anyone know whats wrong with my transfer case???
I just got a 68 GMC 2500 4x4. When we bought it, the guy told us it trys to pop out of gear (in the tranfer case) when backing up, and it succeeds. Anyone know what the problem is? Linkage or inside it? From what they told me in the other thread, it is a Rockwell 221c. It's big and funny-looking if that helps any .
FUNMUDDER is offline   Reply With Quote
Old 10-25-2005, 09:05 PM   #2
FUNMUDDER
FUNMUDDER's Avatar
Re: Anyone know whats wrong with my transfer case???
Anyone????
Old 10-25-2005, 09:15 PM   #3
nu2-72
I am not really sure what you mean when you talk of the transfer case and reverse. Is this a manual transmission or auto, does the trans. pop out of reverse or the transfer stop moving with the tranny in reverse? Remove the linkage and place in reverse. Does it pop out then? It's inside. If it stays in,then it's linkage. You may even look to see how far it travels with linkage attached and how far detached. This would tell you how for out of adjustment it is or give you a starting point. Not knowing if the tranny selector is popping out or the 4x4 high/low shifter,this is about all I can suggest here.
If it is a manual tranny and popping out of reverse it may be the tranny and not the transfer case.
Not enough info to help much. Sorry.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 10-25-2005, 09:50 PM   #4
al's71gmc
4 eyed fever
al's71gmc's Avatar
Check the tranny mounts. If one is broken or lose, maybe the torque in reverse is moving the linkage enuf to disengage. Could also be a bearing going out on the output or input shaft. I had that happen on a transmission before and it would kick out of 1st and 3rd gear. Hope this helps.
Al
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 10-26-2005, 01:27 AM   #5
4x4Poet
Great advice, already. I'll take the obvious.
Remove the transfer case shifter boot so you can see if the lever is hitting the hump opening when the engine torques in reverse. If the lever is real close, consider whether the installed boot is hit while the tranny's in reverse.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 10-26-2005, 07:10 AM   #6
Blazer1970
Blazer1970's Avatar
A broken motor mount could do this also, not just the tranny mounts.
Blazer1970 is offline   Reply With Quote
Old 10-26-2005, 04:28 PM   #7
toroflow
I was grinding down a hill the other day in granny gear and low range in my divorced T-221 ('64 Sub 4x4) when it popped out of low range and into neutral!!! What a scare!!! I don't know what it could be, but I now just hold the shifter in low when descending any big hills to avoid another scare!!
Ken
'60 GMC 3/4T 4x4
'60 GMC Suburban 4x4
'64 GMC Suburban 4x4
toroflow is offline   Reply With Quote
Old 10-26-2005, 09:42 PM   #8
FUNMUDDER
FUNMUDDER's Avatar
Its motor mounts are all good. WHILE backing up, the transfer case pops out of gear in the in 2wd and 4wd HI, but not 4LO , the transmission is fine, and very, very tight.. I'll check the tranny mounts, but I'm starting to think it is the linkage itself. The transfer case shifter is extremely sloppy, too.
Old 10-27-2005, 09:13 AM   #9
1969K10
1969K10's Avatar
I'm just guessing here, but when i rebuilt my Rockwell, there are springs that hold balls in detents in the shafts that move in and out with the shifter. I'd guess that you've broken the spring that holds the high range shaft in the correct position.
checked out your pics, nice score!!! The oiling holes in the bed intruige me, what a concept!
1969K10 is offline   Reply With Quote
Old 10-27-2005, 06:08 PM   #10
FUNMUDDER
FUNMUDDER's Avatar
Thanks for the info. Where can I find parts for a Rockwell transfer? Or would I be better off to start looking for a NP205 to put in?
Old 10-28-2005, 02:08 AM   #11
4x4Poet
http://www.drivetrain.com/transfercasesparts.html
Expensive. Other sites exist.
Old 10-28-2005, 03:59 PM   #12
1969 GMC
1969 GMC's Avatar
If you go to a NP205, you have to move the crossmember back a little bit (1.5" or 2", can't remember), re-do your driveshafts accordingly, and get a 10 spline NP205 from behind a sm465, as well as the adapter and sleeve. If you have a divorced Rockwell (possible I guess) it will make it easier.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-02-2005, 04:13 PM   #13
1969K10
1969K10's Avatar
I believe I went thru Drivetrain. For some exploded views, check out http://www.zianet.com/desertskies/Rockwell%20T-221.pdf
Old 11-16-2005, 02:32 PM   #14
skiscott00
I have a divorced t-221 unit for sale and I also have enough parts to rebuild one as well. Mel 916-670-7395
skiscott00 is offline   Reply With Quote
Old 11-16-2005, 11:43 PM   #15
skiscott00
I had mine do this about 20 years ago and it was the idler shaft. Once I had it replaced along with the springs in the top plate, it took care of the problem.
Old 11-17-2005, 09:52 PM   #16
FUNMUDDER
FUNMUDDER's Avatar
Where did you get the parts for it????? Cali is too far away for me, and I dont like the thoughts of shipping stuff. Are idler shafts a hefty price, or no?
