10-30-2005, 09:26 PM | #1 |
quadrajet
How much cfm do you think the stock 4 barrel quadrajet on my 70 with a 350 is? Is there anyway I can find out?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
10-30-2005, 09:32 PM | #2 |
Re: quadrajet
I think it would be a 750. They made 750's,795's, and MAYBE 850's for Cadillacs. Thats from looking at old Summit catalogs, what they have listed for replacements. They are big though.
10-30-2005, 09:45 PM | #3 |
drive it not trailer it
Re: quadrajet
most are 625cfm for the 350s
10-30-2005, 10:18 PM | #4 |
Re: quadrajet
750's i read the "monster garage, how to customize damn near anything" book, and it said 750 more than a couple of times.
10-30-2005, 10:29 PM | #5 |
Re: quadrajet
Yep, 750. They're dam good carbs when tuned right.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
10-30-2005, 10:39 PM | #6 |
Re: quadrajet
My dad said there is no way chevy put a 750 on a 350 with an automatic stock. He said it would bog down to much. And my friends dad said 500-550 stock. Are there any numbers I can look up?
10-30-2005, 10:50 PM | #7 |
Saving 1 truck at a time!
Re: quadrajet
Sorry BowTieMan, Both John Lingenfelter and David Vizard state in Building and Modifying Small Block Chevys that the standard Q-Jet is rated for 750 CFM. The motor does not have to use the much cfm but the carb can flow that much if and when required.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
10-30-2005, 10:55 PM | #8 |
Re: quadrajet
So is mine on there now flowing 750 cfm? Or is it that they can flow that much? Thanks for the help guys I will just keep this and get a better manifold instead. Man I love this board!
10-31-2005, 12:07 AM | #9 |
Re: quadrajet
When you're just cruising or whatever, the front 2bbls are flowing about 500cfm, and when you hammer the throttle and the 2 big back barrels open up, then it's pulling 750.
10-31-2005, 12:32 AM | #10 |
20' Daredevil (Ret)
Re: quadrajet
The front throttle bores on a Q-jet are tiny (for fuel economy) - dunno what they are rated at but it can't be much. Most of the flow rating comes from the huge secondaries, which (at least on our engines) are vacuum operated, and tha't why the engine doesn't tend to bog at WOT - they only open as much as the engine can handle.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-31-2005, 12:50 AM | #11 |
Re: quadrajet
Thanks for the help guys. Is there any way to tell if my secondaries are opening or not? It never seems to kick in like my dad's 79 suburban did, and if I rev it in neutral they never open and I don't want to rev it too high for too long to see.
10-31-2005, 07:26 AM | #12 |
Re: quadrajet
Get a buddy to push the pedal down while you look down the carb. Not running of course. You'll have to push the choke open to see the secondary plates.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
10-31-2005, 07:48 AM | #13 |
Where's my beer?
Re: quadrajet
You should really be able to tell when the secondaries on a quadradjet kick in. It makes a very distinctive sound, very different from when just the primaries are open.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
10-31-2005, 07:49 AM | #14 |
Re: quadrajet
The air flapper valves on the secondaries will never open when you are just revving the engine in the driveway. The engine has to be under load (low vacuum). There is a vacuum actuator on the carb that holds the flappers shut under high vacuum.
Tim |
