Old 11-03-2005, 04:40 PM   #1
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Will an 85 rearend fit under a 69 swb?
Is it wider or shorter?
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 11-03-2005, 05:25 PM   #2
raggedjim
raggedjim's Avatar
Re: Will an 85 rearend fit under a 69 swb?
It is wider, but not by much. I put one under a 64 chevy truck once and it fit fine (well, after I cut off the brackets and welded the trailing arm style brackets to the housing, you'll also need a provision for the panhard bar)
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 11-03-2005, 05:48 PM   #3
bagged69c10
Im 4 linking it so no problem there, I just hope my wheels will tuck.
1965 c-10 long bed
1993 Sierra x-cab
Old 11-03-2005, 10:17 PM   #4
RJ100
HOW WIDE IS WIDER ? Thinking about a swap like this myself.
RJ100 is offline   Reply With Quote
Old 11-03-2005, 10:23 PM   #5
raggedjim
raggedjim's Avatar
I'm thinking it was .75" each side (1.50" total) but that's been 15 years ago. You may be able to post in the later forums and get one of those guys to take a measurement for you.
Rg
Roger
'70 GMC Jimmy 2wd
