11-04-2005, 08:21 PM | #1 |
T5 and 283
I saw a 68' on ebay, it wasn't running but it had T5 behind a 400. I'm sure it will be short lived. But I was thinking of putting one behind a 283-350 in a 67 to try to get some mileage and have some hiway gear. Is the one out of a S10 the one I need? It seems like the shifters are in different places for the camaro and s10. Anyone done this? The truck will only be used for light hauling.
11-04-2005, 08:28 PM | #2 |
Re: T5 and 283
you need amanual from a 4.3 s-10, it is the same tranny that was put in 90's half tons except the shifter on the s-10 tranny will be at the back of the tranny instead of about the middle. i am using a s 10 tranny behind a vortec 350 - once i get the truck back together.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
11-04-2005, 08:55 PM | #3 |
its all about the +6 inches
Re: T5 and 283
The camaro had the stronger one with the right spline count, you'll need to probably make a custom shaped shifter, not too hard if you can cut and weld...could actually make it look good if you wanted to.
Only rated for 305 ft pounds... I would do it with a 283 or 307, but not to a 350... not if you plan on haulin/towin/hot ridding/off roading. Camaro tranny will need a custom wedge placed under the tranny mount to make it bolt down properly, the T-5 in an F body was turned a few degrees to try and make more foot room in the car. |
