Chevys Kick A$$
Any suggestions for permanantly closing off an opening in a radiator??
I got a huge utility radiator from my buddys brother and installed it in my truck. I had to remove the overflow tank to make it fit. But it takes like 5 gallons of coolant. Its flipping huge. Anyways theres about a 3/4" opening in it that I will not need to use for anything. I got it plugged up tempoairlily but I know it will not hold up. Should I just take it to the radiator shop and ask them to close it up for me or is there something simple I could do to plugg it that will hold for awhile.
-Late
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
You get what you pay for
![]() Join Date: Dec 1999
Re: Any suggestions for permanantly closing off an opening in a radiator??
My question is, what in the world do you want with a 5 gallon radiator?? Maybe I'm missing something here.
Mike 1985 Chevy C-10 |
Umm...the point Senior, the point?
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
Do you mean like this?
Chevys Kick A$$
^ Yeah, just like that. I am getting money tommorow I will just go down to the auto parts store and aske them for something like that. Thanx.
I know its pretty big but it works perfectly and I got it for 15 $$ so I thought I might as well use it. -Later
![]() Last edited by Hoods69BadBowTie; 11-01-2005 at 05:05 AM. |
STILL PLAYS WITH TRUX
You know you can over cool an engine right?
And it will not perform the way it should. |
#7 | |
I'm back with 2nd truck!
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
if you do get it, here is the part number and link.
comes from autozone or that chain store in your area http://www.partsamerica.com/ProductD...rtnumber=02254 |
I took the pic of the package so you would have the part#. The cap pictured is the 3/4" ...corn
Get two of those HELP caps & put one in a ziplock bag in the glovebox. They tend to crack & leak a lot faster than you may think.
Chevys Kick A$$
Do you think that this radiator is going to keep it too kool? Seems to be running fine so far. Same as it did before.
-Later
![]() Last edited by Hoods69BadBowTie; 11-02-2005 at 04:55 AM. |
Insert Witty Text Here
Once it gets up to operating temperature, with a thermostat, it should run at the same temperature all the time.
Slonaker |
#13 | |
![]() Quote:
Remember the Tstat holds water in the block for heat xfer then when the water is heat soaked the Tstat opens now you have super cooled water entering into the block due to a 5 gallon rad this water is gonna cool down way faster than it would in the proper size rad. Thus not allowing the Eng. to reach proper operating temp's. Last edited by 87 STEPPER; 11-02-2005 at 10:43 AM. |
If it cools down too much the thermostat will close off a little until it reaches a state of equilibrium.
#15 | |
![]() I wouldnt worry about it. And for towing and stuff it would be the ticket.
83 'burban 6.2 diesel 4x4 33x10.5 BFG Mud Terrains Last edited by 83Diesel4x4; 11-06-2005 at 09:24 AM. |
