Old 11-03-2005, 09:03 PM   #1
.030over
Junior Member
.030over's Avatar
68 on a 73 up frame?
I thought I had read a post talking about using a 73-87 frame under a 67-72 truck awhile back. Did a search and checked the FAQs but nothing. Anyone have any info on doing this. I just picked up a 77 camper special with 454, turbo 400, 14 bolt, big sway bars. I would like to upgrade my 68 C20 either doing a frame swap or just front and rear suspension swap. Frame widths must be the same as the front suspension crossmember will swap so I was thinking just use the 68 cab mount brackets on the 77 frame. Anyone?
Scott
'67 SWB big block project
'85 C60 school bus motorhome conversion
.030over is offline   Reply With Quote
Old 11-03-2005, 09:27 PM   #2
Re: 68 on a 73 up frame?
It is not a bolt over swap. To make it work you'll need a body lift to fit the newer fram. Asker Mudder67...he did it on his truck. Me, I would move everything from the new frame to the older frame...front corssmemeber, engine rear etc...
Old 11-03-2005, 10:05 PM   #3
krue
Designated A-hole!
krue's Avatar
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-03-2005, 10:22 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Wheel base isn't the same either.
Old 11-03-2005, 10:26 PM   #5
.030over
Junior Member
.030over's Avatar
Although I have cut up and modified a lot of classic cars and trucks in my 42 years, I have felt much more guilty about it lately! I guess a crossmember and rear swap would be less offensive. I would like to use the sway bars and am not sure how much work retroing them to the 68 frame would be. I also have the trailing arm vs leaf spring issue to decide on. I imagine I could change over to leaf springs by cutting the front and rear hangers of the 77.
Old 11-03-2005, 10:29 PM   #6
Longhorn Man
but the trailing arm set up is soooo much bettine in almost every aspect.
Old 11-03-2005, 10:39 PM   #7
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Except when towing, Andy, you remember that longbed I was towing my blazer with? it had trailing arms, I would've been at you house sooner if it had come with leafs, they're so much nicer when you have almost 6,000 Lbs behind you
chevy_fatman is offline   Reply With Quote
Old 11-03-2005, 11:39 PM   #8
Longhorn Man
You know Paul, the first time i towed with the old SWB GMC, I noticed that it didn't track for squat. I had a small (think itty bitty) enclosed U-haul trailer with a washing machine in it, and it felt funny above 65.
I asked about that on here and just about everyone replied with "My trailing are truck tows great... your truck must be a POS" (which... it was)
So the Q is....
Is your truck a POS too?
When you gonna get the Blaze on the road man? It's starting to grow roots!
Old 11-03-2005, 11:57 PM   #9
chevy_fatman
Where's my beer?
So the Q is....
Ok, I'll admit it it was a POS, but a POS with leafs would've tracked better.
I keep repeating to myself "next year", maybe next year?
Old 11-04-2005, 05:20 AM   #10
Mudder
Mudder's Avatar
Is this a 2wheel drive truck?
Mudder is offline   Reply With Quote
Old 11-04-2005, 06:38 AM   #11
.030over
Junior Member
.030over's Avatar
Yes, both trucks are 2wd. 68 is high hump. Considering leafs for the towing aspect only. I regularly pull a 30' Scarab Sport that goes about 7000# and I'm tired of busting up my '94 daily driver.
Scott
Old 11-04-2005, 06:58 AM   #12
Mudder
Mudder's Avatar
You'll probably have trouble with the bed lining up with the cab. I believe the newer frame makes a sudden upward bend right at the back of the cab that may mess with you. You need to do a lot of measuring and comparing differences between the two.
I do not know the differences in the two frames either as for 4wheel drive verses 2wheel drive.
Old 11-06-2005, 10:58 AM   #13
1971custom
1971custom's Avatar
i bought a 1991 suburban 4wd halfton and have put it on my 72 gmc the box lined up great but we had to secton the frame whe used the motor trans axles exc to build the truck so far it has whent pretty smooth im about half done but the 92 frame is diffirent
1971custom is offline   Reply With Quote
Old 11-06-2005, 09:08 PM   #14
.030over
Junior Member
.030over's Avatar
I worked from 10:00am till 5:00pm and got the 77 body all off and cut up. I was hoping for some good parts that I could sell but not much any good. Just about every piece was damaged in some way! Tilt, cruise, AC, woodgrain interior, and every body panel. What a let down! At least I have a good frame, 454 / turbo 400, and 4.10 rear for the 68. Now to make it fit. I didn't have time to do any measuring yet. That will have to wait till next weekend.
Scott
Old 11-06-2005, 09:11 PM   #15
FormerMember
Bet the towing issue could be fixed with a new panhard bar bushing set and possibly a panhad bar stud.
Same with the trailing arm bushings...
FormerMember is offline   Reply With Quote
Old 11-06-2005, 09:23 PM   #16
.030over
Junior Member
.030over's Avatar
Yes...but
True, but then what would I do with all that EXTRA time on my hands and my neighbors wouldn't have anything to ***** about. My welder would get all dusty and my Oxygen and acetylene bottles would last forever! Can't have all that!
Scott
Old 11-06-2005, 09:40 PM   #17
FormerMember
Nah, you need the torches to burn out those bushings...
