#26 | |
Re: What was the 11,000# axle for a C30?
#27 | |
User #12137
![]() Join Date: Apr 2004
#28 |
User #12137
heres the lug measurement
#29 |
User #12137
oh yea the front of this truck is 5 lug and the rear is 10 lug same rims used both front and rear the front just uses every other lug
now i thought this thing had split rims but i got to lookin at them and now i am not sure heres a pick of the rim back side ![]() front side ![]() |
#30 |
User #12137
heres the rear spring pack
![]() heres the tire size ![]() |
#31 |
User #12137
this is a differant rear end is it a ho52 or ho72 ?
#32 | |
User #12137
#33 |
If it is 10 lugs on the rear, then it is the HO110. That rear came in C40 and C50 trucks but it looks like your truck was a special order C30 with the HD suspension upgrade.
Those are split rims, if you look next to the size it says tube type.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
#34 | |
User #12137
#35 |
the lock ring on that kind of rim is removable, but it's a PITA to get it off. you have to get the tire iron in the right spot and pry the ring off. i've never messed with those, but that's what it says to do in the service manual.
#36 | |
User #12137
#37 |
User #12137
is the frame like this on all 1 tons ?
#38 |
looks like a regular c20-c30 frame as far as i can tell.
#39 |
Having issues
If you are going to mess with mounting and dismounting split rim tires, wrap a chain around the rim/tire assembly. I have heard many a story of old timers having the halves seperate and making holes in whatever they contact.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
#40 | |
User #12137
![]() ![]() at local junk yard one of the workers there was changing a tire on a split rim and it came apart and killed the guy and put a hole in the metal roof of the building this happend about 15 years ago the owner of the yard shut the yard down after that happind oh yea thanks for the advise anyway ![]() Last edited by tnblazerk5; 10-27-2005 at 08:34 PM. |
#41 | |
As for 10 lug front axles, try looking for one of the late 90's 3500HD trucks. They have the little gray insert under the grille, and the bumper is farther down than the regular one tons. Those trucks also have 5 lugs up front and 10 in the rear (on 2wd's). I saw one 4x4 that was an aftermarket conversion, it had a Dana 70 front with 10 lugs. The rear axle in those is a Dana 80, iirc it also has disc brakes.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#42 |
Having issues
The ford 60F axle in the prized Ford F250 snow fighter package was rated for 4500# IIRC, nowhere close to 6K. Now that doesn't mean it cant handle a 6K load, its just the factory did not rate it for that load.
A D70 in a front axle application is rated at 5300#, and in the rear the same axle is rated at 7400#. It is rated like that because the front end sees weight transfer during braking, which raises the weight on the front end by a great deal.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." Last edited by masterbeavis; 02-16-2008 at 04:30 AM. Reason: Edited bad GVW ratings + add D70 info to support my claim. |
#43 | |
How do you explain the D60 in the CUCV 1.25 ton rated or in other 2 ton trucks? |
#44 | |
Having issues
#45 |
Having issues
