Active Member
I had the TH400 swapped out for a 700R4 and it has been the best money spent on my truck so far. Stepping up to power brakes comes in a close second! I suggest to everyone to have the swap done. I will have some pics soon.
![]() Sonny |
Born a Chevy Man
Re: 700R4 Swap Succesful!!!
What year 700R4 did you use? What does it take to swap out one of these. Have you checked you fuel mileage yet? Look forward to the pictures. I have been thinking of doing this but at a latter date. Too much going on right now with a daughter getting married and all.$$$$$
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
Having that extra gear sure is nice isn't it? Especially with the steep gears some of these trucks had.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Yeah, makes me smile too everytime mine goes in fourth gear as well.
![]() Join Date: Sep 2005
Did you do it yourself? For those of us who are more inclined to just write a check, where did you have it done, and if you don't mind me asking, how much did it cost?
1968 Custom SWB, 327/3 speed OTC 1969 CST LWB, 402/400 1970 CST LWB, 402/400 1970 Sierra Grande LWB, 350/350 1971 Cheyenne LWB, 350/350 1972 Cheyenne Super LWB, 402/400 1972 Sierra Grande LWB, 402/400 1979 Silverado LWB, 350/350 1984 Suburban 1990 454 SS 1991 Silverado, X-cab, 4.3/5 speed Getrag 2005 Silverado Crew Cab Corvettes: 75, 77, 78, 93, 96 |
Born a Chevy Man
Yes Sonny, how about some answers?
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
I havent done this on my 72 yet, but I did it on my 70 Nova and I had to move the X-member back, I believe that the trans lines are the same from T-400 and T-350 locations on the housing to the radiator, shorten the driveshaft(s), and then the obvious linkage issues.
On my Nova, the stock stamped/curved linkage arm wasnt long enough to engage 1st gear, so on our trucks, I dont know what the linkage issues are as of yet... Thats my 2$...
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
Born a Chevy Man
2$ worth is better than 2cents worth.
The Lokar linkages are perfect to use on our trucks. They also allow you to un the exhaust over the trans crossmember with out the linkage being in the way.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Do you have any pics of a Lokar linkage in a 67-72 application with a 700R4?
Link to that site?
Born a Chevy Man
I would like to see that picture too if you have one. Or if anybody has one.
yea SONNY let us know alittle about the install. I.E. cost
#13 | |
The LuvShack Garage
![]() Join Date: Oct 2005
I did this swap, from a th350 short tail shaft to a 700r4, just moved the crossmember back and sent the driveshaft out to be shortened in my
1971 GMC 1/2 ton LWB. I had a 12 bolt rear with 4:10 gears and went from 8mpg on the highway to 15mpg, definitely worth it. In my current project I am using a gear vendors overdrive setup since I do not trust the 700r4 to stand up to towing use |
#15 |
Active Member
Pictures will come soon. I had a reputable shop intown do the work for me. I traded my tranny and some coin for the 700r4. He installed it 4 me including shortening the shaft, misc parts and pieces, and even threw in a 12 month warranty. He did a great job too. I have a push button switch for TC lock up, but I am going to replace it with a momentary switch using a holding circuit through the brake pedal switch to disengage the TC when I hit the brake.
![]() Sonny 1968 Chevy C-10 Shortbed |
#16 |
Project92 SWB stepside
Sounds like you spent some $$$$ for that?
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#17 | |
http://12.215.122.222/700R4.htm |
#18 |
I'm doing it to my 71 4x4 right now. It is going to run me about $2200. But is is worth every penny. I did it to a 72 4x4 I had and loved it. You have to move the trans mount the transfer case mount. You also have to add length to the front shaft and shorten the rear shaft. I'll hook the lock up converter to my brake. Adding the 4th gear was wonderful as well as the low first gear I can take off faster than ever before.
#19 |
Senoir Member
I think you can buy a pressure switch to install in the trans that will lock the TC at a certain pressure. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
#20 |
![]() Join Date: Nov 2004
Bowtie overdrives sells a kit for about 70 bucks to lock up the TC, it also has a switch that you connect to your brakes to unlock it. I'm going to get a new rebuilt tranny from them and get thier kit in a few months.
I can vouch for the brake switch as being needed. I only had a pressure lock up switch on my 700R4 and I had to slam the brakes on my 67 to miss a deer. I missed the deer but in the process the engine died and I lost my brakes. Power brake trucks take forever to stop without the engine running!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
