Old 11-07-2005, 07:30 PM   #1
76bonanza
76bonanza's Avatar
spark plug suggestions
Getting ready do replace wires and plugs. I have an accell HEI with msd module and accell super coil. built 355 around 330 hp.
I am looking at NGK ugrooves or good ole ac delco. Two question
Which ones do you suggest part (ie acdelco r45) and what gap thinking .45 or so?
I know this is a debatable subject but just need help deciding.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 11-08-2005, 02:02 AM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: spark plug suggestions
Personally I'd go with ac delco r45ts if you have small plug heads(5/8) or the r 45 if you have the big plug heads(13/16). Out of all the othe plugs out there ngk would be the only other thing I'd run other than delco. Just my .02 cents.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 11-08-2005, 12:21 PM   #3
farside847
farside847's Avatar
Stock is a .35 gap. I dont know if Id go over .40
What gap are you running now? Increase it a little and see how it
runs, you can always gap them bigger after a few days.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 11-08-2005, 12:31 PM   #4
70rs/ss
70rs/ss's Avatar
Run .45, with and HEI and bigger coil it should be able to throw a longer hotter spark.
70rs/ss is offline   Reply With Quote
Old 11-08-2005, 03:56 PM   #5
Jim_PA
I've used Autolite 25's in every SBC I've owned (well, that's only been 4), but they work well for me.
Jim_PA is offline   Reply With Quote
Old 11-08-2005, 06:31 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I had R44's with the stock points distributor but went to R45TS plugs, they burn really clean and I never had a problem with 'em.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 11-08-2005, 08:34 PM   #7
Fatback
Fatback's Avatar
Autolites for me too. I bought one set of AC's for my 79, one plug was dead....I ended up having to use of the Autolites I took out.
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Fatback is offline   Reply With Quote
Old 11-08-2005, 10:04 PM   #8
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Autolite 26's for me. I don't buy any of the fancy spark plug gimmicks.
.045 gap is proper for an HEI system.
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 11-08-2005, 11:48 PM   #9
Jim_PA
26's are what... 1 step colder I believe?
Old 11-09-2005, 08:05 AM   #10
70c10
67-72 Addict!
70c10's Avatar
I run Autolite AP 26 plugs and like them.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-09-2005, 11:24 PM   #11
Green Machine
Green Machine's Avatar
What ever you run, get something with an extended tip, runs cleaner and puts the spark that much closer to the center for faster burn. I've been using champions, but some don't like champions.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-10-2005, 02:10 AM   #12
55chevy
Car Truck Bike Nut
55chevy's Avatar
I didn't like the cheap Autolites I bought, I have had good luck with Bosch Platinum plugs, the low cost ones, always had good luck with them, they cost a little more than AC and Autolite but they are worth it.
Snow free Florida panhandle, don't miss Indiana winters
Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL
68 shortfleet project
94 3500 TD dually
so many cars so little time
72 K2 CST 2WD Blazer
55chevy is offline   Reply With Quote
