11-10-2005, 11:57 AM | #1 |
Will a 72 K20 axle (dana 44?) fit on a 77 k10?
quick question- will a 72 k20 axle (dana 44?) fit on a 77 k10? Are the springs the same width apart, etc.? I owe the PO of my 77 stepside the front axle, and may buy a 72 k20 for parts. Thanks very much!!
Crosby 1978 Chevrolet K10 stepside NH |
11-10-2005, 12:19 PM | #2 |
Re: Will a 72 K20 axle (dana 44?) fit on a 77 k10?
Yep, the front axle will bolt right in place with no mods. The rear axles do have a different spring width though.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
11-10-2005, 12:26 PM | #3 |
excellent, thank you! Isn't the 72 the closed knuckle design (less desirable?)
11-10-2005, 12:46 PM | #4 |
Nope. The 69 was the last year that you should find the closed knuckle Dana 44.
11-10-2005, 12:49 PM | #5 |
So it should be the same then as my 77ish K20? Not a bad axle if you ask me. Just a step below a dana 60. This 72 does have the useless Eaton rear. I think the frame and running gear is original, after looking at it yesterday. Thanks Jack!
11-10-2005, 03:37 PM | #6 | |
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
11-10-2005, 03:47 PM | #7 |
Sorry Adam, no offense meant. Just saying that for the purposes of buying this truck, that's not a high demand part (I don't believe). Let me know if you want it
11-10-2005, 05:56 PM | #8 | |
11-10-2005, 11:28 PM | #9 |
Keep in mind the 72 d44 uses smaller shafts andu-joints and the hubs don't seal worth a ****. Just let him know its out of a 72 so when he needs parts he won't be baffled.
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
11-11-2005, 01:19 AM | #10 |
Hi Doug. No, I was going to use the 44 to roll around what was left of my 77, that's all. Thanks for the info!
