Old 11-11-2005, 08:20 PM   #1
Slatherd
brake light on dash. wont go out.
A few years back, I went through a snow bank. Ever since then, I cant get my brake light on my dash do go out. When I push my emergency brake, it gets brighter. When I release it, it goes dimmer.
It's really distracting when night driving. It used to blink which was worse. Now it just stays on.
Check out my profile to see my truck. 1991 GMC 2500.
Slatherd is offline   Reply With Quote
Old 11-11-2005, 09:00 PM   #2
ChevyTech
Re: brake light on dash. wont go out.
I am assuming this is on your 1991 GMC. It sounds to me like you have a truck with RWAL. RWAL stands for REAR WHEEL ANTILOCK.
There are three brightness levels of the dash brake indicator light on RWAL equipped trucks.
Brightest – park brake
Medium – Combination valve (aka metering & proportioning valve)
Dim – RWAL System
This system can store trouble codes. You can retrieve RWAL codes without a scan tool.
To retrieve RWAL codes connect a jumper wire between terminal H and terminal A of the ALDL connector with the key on (engine not running). Watch the dash brake lamp and count the blinks. Sometimes RWAL system send out a phantom blink before the code blinks start. It can take up to 20 seconds for the code to start coming out.
Checking the code with this method can set a false code 9.
If you get one long flash and 5 shorter flashes that is a code 6.
The RWAL system is only capable of storing one code at a time.
You can clear the code by removing the fuse for 10 seconds then reinstalling it. The fuse should be labeled STOP or BRAKE.
It is possible to set a trouble code without having a failed part. Something as simple as spinning the tires in the snow can set an erratic speed code.
If it were my truck I would read the code, then clear the code, and drive the truck and see if the code comes back again.
Here are some sites that have some RWAL info:
http://autorepair.about.com/library/faqs/bl929g.htm
http://www.babcox.com/editorial/tr/tr89850.htm
ChevyTech
