Old 11-06-2005, 02:47 PM   #1
1967k30
1967k30's Avatar
Eaton info
I need some part #'s for the hub bearings and seals for my brothers Eaton.I've tryed going to the parts store with the old #'s that are on the bearings and they are and won't try to look they up.I also was wondering if 9/16" studs will go right into the same hole I took the 1/2" out of.I knew at one time but I've forgotten.
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 11-06-2005, 02:57 PM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Eaton info
What kind of rear end is it? HO52 or HO72. Got any pictures? I have the bearing and seal numbers (NAPA) wrote down somewhere.
D.PASSMORE is offline   Reply With Quote
Old 11-06-2005, 03:03 PM   #3
1967k30
1967k30's Avatar
Re: Eaton info
It's a h072 3rd w/ Detroit and load bolt,h072 70"wsm housing,and h052 63" hubs. They all look the same,except for the one I shaved for more ground clearance .
Old 11-06-2005, 03:19 PM   #4
wolfthing2000
Re: Eaton info
I agree, Napa should be able to help.
wolfthing2000 is offline   Reply With Quote
Old 11-06-2005, 03:48 PM   #5
1967k30
1967k30's Avatar
Re: Eaton info
Napa is where I went.Our local store sucks.
Old 11-06-2005, 04:40 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Re: Eaton info
I've heard you can also get stuff for these axles at carquest, but napa is probably cheaper.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 11-06-2005, 04:51 PM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Eaton info
Alright, I'm not at home to verify but, I had these parts boxes in my truck.
In the brake hub there is 2 sets of bearings and one seal.
Seal # 28426 (NAPA)
I'm not sure if this is the front wheel bearings or not. I belive its the rear .
Bearing & Race # 362-A and 368-A / KB-116302 (NAPA)
Bearing & Race # 382 and 388 / KD- 11786Y (NAPA)
Hope this gets it done!
Old 11-06-2005, 05:55 PM   #8
1967k30
1967k30's Avatar
Re: Eaton info
Thanks,I'll try it.What about the studs?
Old 11-06-2005, 06:16 PM   #9
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Eaton info
LMC Catalog!!! Pull one and match it at the parts store, not sure myself.
Old 11-11-2005, 11:40 PM   #10
1967k30
1967k30's Avatar
Re: Eaton info
Just wanted to post up some P.N.'s.The larger bearing and race is NAPA # KD11786-Y,the smaller one is KB11630-Z or 2 I can't read the writing{they wrote it down,didn't have in stock},and the seal is 28426. The large set was $85.05 for the pair and the seals were $15.16 for the pair.They are sure high priced but they are avaliable.I also asked about carrier bearings and such for Eatons and they said they could get them.I hope this helps someone else.
