Old 11-10-2005, 02:51 AM   #1
my85dually
my85dually's Avatar
Lower Gear Ratio in my dually
I have a question. Has anyone every changed their gears in the rear-end of a dually to a less steep ratio. I have 4.10 in the rear of my dually. I wanna put like 3.25 or maybe 3.50. any ups or downs? I dont tow much with it, so thats not a factor for me. I want it to be a highway crusier.
Mike
ALSO does anyone know what Rig I can get a non-electric 4-speed auto out of, that will bolt to my 454.
thanks
1985 Silverado Club Cab Dually
Viva La Dually!
my85dually is offline   Reply With Quote
Old 11-10-2005, 08:16 PM   #2
SanitysBane
Re: Lower Gear Ratio in my dually
They went to the full eletronic 4 speeds in 92 or 94. All the ones before have a lock up TQ that you have to rig up somehow. And any transmission that will work on a small block will work on a big block. Just make shure that your flexplate has the correct bolt pattern.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 11-11-2005, 10:14 PM   #3
u2slow
Web Wheeler
u2slow's Avatar
You have a dually pickup as per your avatar?
That would be a Dana 70HD axle... you can put in a 3.54 ratio no problem.
There are some odd-ball Dana 70 variants out there with numerically lower gears, (3.07 & 3.42 come to mind) but they have unique housings, so the gears won't swap.
I wouldn't bother with the TH700 OD trans. Its more work (driveshaft, crossmember, cable/linkage, etc.) and your 454 will ensure its lifespan is short.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 11-13-2005, 12:47 AM   #4
my85dually
my85dually's Avatar
Thanks for the replies! So dont worry about a 4 speed auto with the 454, ok. I will be able to buy 3.54 and install them no prob, GOOD!! I value this board because of people like you! oh and Yes that is the dually I am speaking of in my avi.
thank you very much ,
Mike
Viva La Dually!
Old 11-13-2005, 10:59 AM   #5
Tom
driving is in my blood
Tom's Avatar
You can get a non computer controlled 4L80E [what comes behind big blocks from the factory from GM] and put it in there and keep your 4.10's while still saving a good 1000rpm on the freeway. Cost in the $2500-3000 range. Either that or a normal 4L80e and put the stand alone computer managment in [about $500+ the cost of the tranny]
Old 11-13-2005, 11:58 AM   #6
SSC's76
No No
SSC's76's Avatar
Mike
Well I'd talk to Dana at Probuilt. http://www.700r4l60e.com/store/customer/home.php?cat=20 They make quite a few 700R4's that will tame your big block and they dont cost much more then having a local guy do a stock re-build. Just shoot them a message there always glad to help. A 700R4 is perfect for cruising the freeways.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
