Old 09-02-2002, 12:21 PM   #1
COBALT
COBALT's Avatar
Shims behind the upper control arms???
So I got the lower control arms off, and the springs out, and I'm about to bang out the upper ball joint, and pull the upper control arms. I noticed on one side I've got these thin wierd shaped pieces of metal behind one of the upper control arm assemblies. They look like shims. What gives? If I'm replacing everything do I really need to worry about those shims? I'm going to clean them, and keep them in the right order in case I need to reinstall them, but I have no idea why you'd need them there unless your spindle didn't line up correctly, or an incorrect part was used and this was a solution to making it fit....
Any ideas?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 09-02-2002, 12:30 PM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Are you talking about the alignment shims? You will need them.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 09-02-2002, 12:49 PM   #3
minibike
minibike's Avatar
I rebuilt my front end, and put the shims back in the same places. It will have to be aligned and adjusted, but having the shims in will most likely save the guy aligning it some time. He may add or subtract some, but it should be close. These are used for caster/camber adjustments.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 09-02-2002, 02:00 PM   #4
72gmcshorty
72gmcshorty's Avatar
If you are rebuilding the front end, just leave the shims off. Take your truck to get alligned immediately after and they will put new shims where needed. I rebuilt my front end and my shims were crusty and rusted. I think they fell apart when I tooke apart front end.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 09-02-2002, 04:49 PM   #5
COBALT
COBALT's Avatar
Ok, so they loosen up the upper control arm and slide these in? Hmm...I might leave them out and let the alignment shop worry about it.
Thanks...upward and onward.
Seattle, WA.
Old 09-02-2002, 09:23 PM   #6
minibike
minibike's Avatar
Okay, fellas. All I am saying is that each frame is different. Yes, you can leave them out and spend a little more time in the waiting room of the alignment shop reading "Time" magazine. The alignment shop will shim it out to the required distance. No big deal. Dang...you would think I said something about your mother...
69 SWB
LT1/4L60E
Old 09-02-2002, 10:02 PM   #7
Zkast
Zkast's Avatar
Do yourself and the alignment shop a favor... Tag or ziptie the shims and mark which side they came from. Keep them as an assembly (RF, RR, LF , LR) per control arm.
You'll be saving the poor guy that gets to align your truck about 1 hour of pis'n and moan'n. There's nothing I hate worse than a vehicle that comes in for an alignment that someone else has "Hung" parts on. It takes twice as long to bring everything back into spec.
Zkast is offline   Reply With Quote
Old 09-02-2002, 11:58 PM   #8
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Last time I took the cheyenne in for an alignment, the guy couldn't get it do align. Says the center link is bent or something. He got it good enough to stop eating the tires off, but its not exactly right. Do you think one from a bone yard would work? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 09-03-2002, 12:56 AM   #9
COBALT
COBALT's Avatar
Ok, guys...I think either leaving them in or out would probably be ok in the long run.
I got them out and they're pretty rusty and grimy, so I soaked them. I'll decide if I want to put them in when I start putting everything back together....
Seattle, WA.
Old 09-03-2002, 01:09 AM   #10
flaco
I have always marked them and put them back in untill I got the alignment done. In fact, I changed the upper control arms on a 68 pontiac 2 years ago and it still hasn't gone in for an alignment and it handles fine with no tire wear. If you don't put them in chances are it's gonna drive like crap on the way to the shop. It's not that much more work to put them back in. A few minutes work for a piece of mind is cheap.
67 Grand prix convertable 68 Chevy 3/4 ton truck 66 Cadillac sedan deville
flaco is offline   Reply With Quote
