Old 11-12-2005, 09:30 AM   #26
bigblock73
yeller
bigblock73's Avatar
Re: Check out my buddy's truck.
GM NEVER made a 73-87 crew cab short box...2 or 4 wheel drive. If you see any of them, they were done by a conversion company or by the owners themselves.
bigblock73 is offline   Reply With Quote
Old 11-12-2005, 03:23 PM   #27
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Originally Posted by Tx Firefighter
Sure...
Thanks for the info. Very cool, indeed.
The stance looks good. Boy, those 17s look like 15s.
BTW, although it is a 3/4 ton, did he use drop spindles designed for 1/2 tons? There's been questions in the past whether drop spindles for 3/4 tons exists or whether they are the same regardless of the rating.
Again, thanks...
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 11-12-2005, 07:13 PM   #28
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Again, thanks...
Are you sure it is a 3/4 ton? Those look like 5 bolt wheels to me.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-12-2005, 10:29 PM   #29
boxrodz
boxrodz's Avatar
Slonaker
Slon-
You're right, they are 5 bolts. But, Tx FF mentioned that it was 'technically' a 3/4 ton. My guess is that he's using dropped spindles, rotors, A-arms and crossmember from a 1/2 ton.
boxRODz
Old 11-13-2005, 04:43 AM   #30
Slonaker
Slonaker's Avatar
Slon-
I was thinking he just went with 1/2 ton suspension with heavy duty springs. Then it would be "technically" a 3/4 ton because it was originally one. Just like a truck converted from the Oldsmobile based diesel to a gas engine is still "technically" a diesel as far as emissions testing and things go.
Maybe the OP will tell us.
Slonaker
Stock '01 Silverado
Old 11-14-2005, 05:46 AM   #31
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Sorry for the confusion.
He used a complete 1/2 ton front crossmember and suspension with the BellTech stuff for 1/2 ton application.
The reason I said it's "technically" a 3/4 ton is that the title if for the original 4 door heavy duty donor truck he started with. In Texas, that gets him off the hook on needing catylitic converters and smog pump and junk. Just pure hotrod SBC under the hood that passes inspection every year without worry.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-15-2005, 12:46 PM   #32
boxrodz
boxrodz's Avatar
Thanks for clarifying, Tx FF...
boxRODz
Old 11-21-2005, 10:17 AM   #33
454ss_2
454ss_2's Avatar
Man! that is one sweet ride.
90 454ss
92 454ss
00 Silverado
08 Avalanche LTZ
454ss_2 is offline   Reply With Quote
Old 03-15-2006, 09:45 AM   #34
N2TRUX
Happy to be here
N2TRUX's Avatar
Got any more pics?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-15-2006, 10:38 AM   #35
Ziptar
Diesel Addict
Ziptar's Avatar
Nice! I think a 2WD SB Crew Cab is going to be the next project for me.
1979 C-10 Silverado w/ Olds 5.7L Diesel
Ziptar is offline   Reply With Quote
Old 03-15-2006, 12:18 PM   #36
Jim85IROC
Jim85IROC's Avatar
I liked it better as a 4x4, but still very nice.
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 03-15-2006, 08:42 PM   #37
tbirdman88
87 short crewcab
tbirdman88's Avatar
This is question for tx firefighter
i need to find out what your buddy did about the rear shocks,when he put the 1/2 ton rear end in it. im building one also,youve probably seen it , listed as 87 shortcrewcab. is there any way i could get in touch with him, i have a few questions. you can send me his number by e-mail or have him e-mail me.
thanks-donnie
tbirdman88@msn.com
tbirdman88 is offline   Reply With Quote
Old 03-16-2006, 01:45 PM   #38
Crank
Crank's Avatar
Hah. That gives me ideas. I just picked up a 79 Crewcab yesterday from the engine builder in my town. It's a 3/4 ton, I think I'll leave it that way, with the 14 bolt and big lug wheels, They make some decent looking 8 luggers nowadays. But I'd like more info on the shortbed conversion if he has any. I'd like to shortbed my truck I think. But that truck is probably one of the sickest I've seen. Do they make drop spindles and trash for 3/4 tons?
Brandon
Crank is offline   Reply With Quote
Old 03-16-2006, 06:15 PM   #39
bluex
bluex's Avatar
Brandon
Not sure about the lowering stuff, but as far as making it a shortbed:
Get your new bed. Toss it up on there (after you remove the longbed of course ) Whack about 4.75-5" off the end. Measure about 15 times and whack 14" out of the middle. Get a shortbed 16 gal gas tank, Shortbed brake line from under the cab to the axle, shortbed parking brake cables and have your driveshaft shortened.
Congrats you now have a shortbed. Its not as much work as it sounds. Park brake cables are $10/each new from LMC. I got a junkyard tank, brake line and bed for $450, $78 to have my DS shortened and balanced with new u-joints. $60 for a friend to come over with his welding rig and help me chop and weld it back. All in all about 2 days hard work.
bluex is offline   Reply With Quote
Old 03-16-2006, 10:29 PM   #40
tbirdman88
87 short crewcab
tbirdman88's Avatar
hillshotrods.com
check out this link, this is one they did ,it was in the may 2004 truckin magazine.
donnie-87 short 1/2 ton crewcab
Old 03-16-2006, 10:57 PM   #41
bagged74
its just $$$$$
bagged74's Avatar
Originally Posted by tbirdman88
hillshotrods.com
that one is still 3/4 ton, but still bad a$$
bagged74 is offline   Reply With Quote
Old 03-16-2006, 11:02 PM   #42
candyman70
candyman70's Avatar
very cool truck! it looks much better on the ground!
Kyle
70 Model Short Fleet
candyman70 is offline   Reply With Quote
Old 03-17-2006, 01:11 AM   #43
Russell
Professional Grade
Russell's Avatar
Is your buddy from here in Ardrossan?
There is a rig that is the perfect clone of that one up here, and yes, its absolutely gorgeous!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-26-2006, 12:28 AM   #44
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
Yes, I've built one before and did it the same way as bluex. Iit can be done fairly inexpensively and fairly quick as well. Be sure take out your 14" deadnuts and the shortbox will bolt on perfectly, if done right all 8 bolt holes should line up and your cab to bed gap should be even too.
I am about to build another one this week, but this time im going to attempt taking a complete reg cab shortbed and just stretching the frame it 33" under the cab and just swapping the reg cab out for a 4 door cab. i initially thought this would be a quick and easy swap but upon closer look under the 2 cabs the crew cab has straight frame rails and the reg cab frame kicks up after front body mount. Shouldnt be too bad but that does ad a little twist to the plans. I will post info and pics of the build if anyone has any interest in seeing this done. btw, beautiful truck! Looks awesome!!
milehightoyz is offline   Reply With Quote
Old 03-26-2006, 07:05 AM   #45
Tx Firefighter
thanks-donnie
tbirdman88@msn.com
Donnie, sorry, I just saw your post. I'll send your email address to him. He's a good guy and will surely answer your questions.
Old 03-26-2006, 06:59 PM   #46
75Chevy90Kawi
the green machine
75Chevy90Kawi's Avatar
very nice! i think a little better as a 4x, but still nice. not a big fan of the cowl hoods on our year trucks though. just my .02
1975 Silverado - 450 horse crate 383 stroker, 20" Centerlines, Flowmaster exhaust, Hooker headers, full MSD ignition & more...
2003 Suzuki TL1000R
1985 Kawasaki JS550 hull - project ski - WILL have - 650, footholds, custom paint, 4* bars, bilge setup, and more...
My pictures
75Chevy90Kawi is offline   Reply With Quote
Old 04-01-2006, 10:50 PM   #47
longhorn70gmc
longhorn70gmc's Avatar
MAN!!!!!
TX FIREFIGHTER, Your buddy's truck is sweet looking!!!!!! I love the color!!!
Respectfully
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
