Old 11-14-2005, 08:45 PM   #1
sr67chevyfleet
Question Loose steering wheel HELP?
When Im driving I can turn my wheel to side to side 5-10inches or so without the truck responding what causes this to happen. Is it an easy fix. Balance? Im clueless on the whole thing.
sr67chevyfleet is offline   Reply With Quote
Old 11-14-2005, 08:58 PM   #2
JimKshortstep4x4
Talking Re: Loose steering wheel HELP?
You can have someone look at the steering components while you turn the steering wheel back and forth, (you don't need to run the engine to check slack). Typical items where slop is likely include tie rod ends, drag link, rag joint and steering box but everything should be inspected.
Jim
Old 11-14-2005, 09:02 PM   #3
matthufham
have someone turn the steering wheel and keep an eye at the bottom of the steering gearbox on the frame. if they move the steering wheel, and you see no movement under the gearbox, get the gearbox rebuilt.
matthufham is offline   Reply With Quote
Old 11-14-2005, 09:11 PM   #4
sr67chevyfleet
How much will it cost to get the gear box rebuilt?
Old 11-14-2005, 09:31 PM   #5
matthufham
hundreds, sorry man. i'm looking for a new seal for mine right now because it's leaking, maybe yours needs more fluid.
Old 11-14-2005, 09:34 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
do you have manual steering? They seem to be 10 times sloppier than power assist.
if so, may be a good time to upgrade?
Old 11-14-2005, 09:42 PM   #7
truckdude239
truckdude239's Avatar
i have manual steering and just installed an new gear box heres the link http://www.partsamerica.com/ProductL...ering+Gear+Box
148 buxs -250 buxs for an rebuilt one
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-14-2005, 10:02 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm radical here, but I'd use that handy adjusting screw that is on there to attempt to remove the slack before I blindly replaced the gearbox.
Loosen lock nut, tighten screw some, tighten locknut. Price? Free.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-14-2005, 11:31 PM   #9
Longhorn Man
Although I would also try that too.... there is no way that adjuster will get rid of 5 inches of play.
