Old 11-14-2005, 12:16 AM   #1
Free88
Free88's Avatar
Ford 9" Into A Chevy Pick Up
Anyone with info or links on how to properly install a ford 9" differential into a Chevy pick up. Novice at this and would like some info or web sites that explain how to do it properly. Especially getting the pinionshaft and trany lined up properly. Any help appreciated. Thanks
1986 Silverado Short box fleet side. project
2005 VW Tiguan 4 Motion
1997 Blazer S10 4x4
1990 Chevy Silverado K1500 Extended long box
Free88 is offline   Reply With Quote
Old 11-14-2005, 11:26 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Ford 9" Into A Chevy Pick Up
I'm pretty sure SanitysBane has a Ford rear in his truck. You might PM him if he does not drop in.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-14-2005, 12:08 PM   #3
Free88
Free88's Avatar
Thanks. I will do that if he does reply.
1997 Blazer S10 4x4
Old 11-14-2005, 12:39 PM   #4
86 GMG
i have a 9 in in my 86 chevy also the pinoion pitch wasnt a concern of mine when i built it but i didnt notice any diffrents after it was in, i just cut of the chevy brackets and welded to the ford so that it was a direct bolt in. it has disc brakes. i spent a little extra money and had the ford yolk to the chevy driveshaft so that i coukld just buy a u joint for thwe lincoln car and be happy they also make a chevy ford combo i wasnt interessted in that basically i just eyeballed the to rear ends to match and started welding
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 11-14-2005, 04:13 PM   #5
Moostifer
a fool with no money
Moostifer's Avatar
http://www.cachassisworks.com/
this site, along with their catalog helped me alot....
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 11-14-2005, 11:38 PM   #6
SanitysBane
Hey hey I heard my name. Yeah I got a 9 under my ride. It came out of a mid 80s F-150, and is about 1/2inch wider than the factory GM rearend. We used the shock mounts off of the GM rear end, and used the Ford spring perches. We used an angle measure and with the jok perpindicular to the ground and measured the angle on the perch. We then did a TON of measurements and got the springs perches the correct length apart and then did the same thing with getting the perches back on. Got the jok perpindicular to the ground and used the angle measure. Got my truck(83 Long bed with 700R4) I used a jok out of a the mid80's pick up and then used a drive shaft out of a 1988 chevy pick up, 1/2ton 2WD 700R4 long box, and used a conversion rear u-joint. We also kept the drums in the rear and just bolted on the brake line from the Gm to the Ford. We also rebuilt the center section and redrilled the axles and brake drums and total it took around a week give or take. All in all I am very satisfied with everything. If you need any pictures of anything, just give me a shout.
Sorry I can't spell worth beans...
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 11-15-2005, 03:46 AM   #7
Free88
Free88's Avatar
Thanks a lot guys, the info is great. Will take all into consideration and will look forward to your pics.
1997 Blazer S10 4x4
Old 11-15-2005, 11:13 AM   #8
bigarmzz
bigarmzz's Avatar
you have any pics of what this rear looks like on your truck?..
just curious about the whole 1/2" longer thing and what it looks like
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 11-15-2005, 08:01 PM   #9
SanitysBane
The rearend is 1/2inch wider total, so only 1/4 per side. Not really noticeable, plus the rear track it narrower than the front on these trucks from the factory.
'88 K5 Blazer
