Old 11-15-2005, 12:00 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
Casting #'s
Still looking for an engine. Can someone look up these numbers for me?
Block- 3914678
Heads- 3782461
Thanks in advance.
John
Ole Blue 68 is offline   Reply With Quote
Old 11-15-2005, 12:13 PM   #2
woodridge
woodridge's Avatar
Re: Casting #'s
As per Mor Tec, 3914678= 68, 302 327 350
3782461= 64-66 camel hump, 160/62cc ports, 62cc chambers. Are these numbers what you have or what you are looking for?
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 11-15-2005, 12:18 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Casting #'s
That engine number was used on three different engines.
Year number size hp Low High carb vehical
1968 3914678 302 290 290 2/4 Camaro, Z-28
1968 3914678 327 210 350 2 car & truck
1968 3914678 350 295 295 2 Camaro/ChevyII
The heads are
1962-67 3782461 327 1.94 1.5
So if you got these numbers off an complete engine with heads, chances are the engine is the 327.
This info is from http://www.nastyz28.com
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 11-15-2005, 04:09 PM   #4
Ole Blue 68
Re: Casting #'s
Thanks Woodridge and John. It's for an engine I am looking at. Seller claims its a 327 out of a Camaro. It sounded right but I just wanted to make sure.
John, if I'm reading that website correctly, it says the block is rated up to 350HP right?
Old 11-15-2005, 05:39 PM   #5
toms68cst
toms68cst's Avatar
Re: Casting #'s
That's the same block that 's in my truck (Stock 327, large journal 2 bolt mains)
It'd be interesting to run the numbers on the crank. That could be a 302 if its a Camero block.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 11-15-2005, 09:07 PM   #6
John Fabris
TOTY 2006
Re: Casting #'s
If it is the factory camaro engine, it was rated at 295, if it came out of chevy car or truck, it was anywhere from 210 up to 350.
John Fabris
67 C10 SWB
Old 11-15-2005, 10:00 PM   #7
Ole Blue 68
Re: Casting #'s
I'm considering dropping a 327 in my truck (it currently has a 283) since that is what it originally came with. And if I can't find a truck motor, I'm gonna try and find something close.
