Old 11-15-2005, 09:51 PM   #1
uncle
Brake line ?
Can someone tell me why the lines are run different on 1/2 and 3/4 ton disc brake trucks? I'm talking about the lines running from proportioning valve to the master cylinder. They are setup exact opposite. 1/2 ton lines are run with the lines matching front to front and rear to rear. 3/4 ton runs front to rear and rear to front. ( I know, 1 day I'll learn how to post a pic).
uncle is offline   Reply With Quote
Old 11-15-2005, 10:33 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Brake line ?
Speculation here...
The 1/2 ton has tiny brakrs in comparison to the 3/4 and one ton trucks. Therefore, less flud volume, and pressure is needed to actuate the 1/2 ton brakes.
So, if you make the weaker(1/2 ton) components, not work on the bigger systems, then people are less likely to use the improper part.
Speculation...but it does make sence though.
Old 11-16-2005, 04:33 AM   #3
Americanrider
Re: Brake line ?
FYI... I discovered that 1 ton lines are run the same as 3/4 ton lines.
Americanrider is offline   Reply With Quote
Old 11-16-2005, 06:05 AM   #4
Longhorn Man
Re: Brake line ?
one tons and 3/4 tons are more similar than they are differant.
