additional threaded hole?
I was looking over the built 250 I bought the other day, and I noticed that there is an 'extra' tapped hole that my current 250 doesn't have.....on the back of the engine, right below the pushrod covers, there is one hole on my current 250, right below the last bolt that holds on this cover, on the new one, that same hole is there (believe its where the oil pressure sender threads into)....but there is a second, looks to be larger hole right between the second and third bolt that hold this cover one.....anyone know what its for? I will try to post pics when I get a chance.
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: additional threaded hole?
right here?
is that the pic you meant to post? The hole I am talking about would be just infront of the oil pressure sender at the far right of your pic.....your pic. doesn't show the location I am talking about.
Still Green but learning
I have some on my 350 I think. My friend who rebuilds chevy engines in spare time said he usually bolts down the grounding straps there. currently my straps run from the firewall to my valve covers.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was Last edited by phlegm; 11-15-2005 at 12:46 PM. |
Questionable
That pic above just shows the sending unit for oil and the connector is hanging (that's one of my pics from my 250's
![]() Here are a couple of "better" pictures of that side of the engine on both of my 250's: The hand points to the sending unit hole. Are you talking about the other hole near the dipstick? http://satellitehead.com/images/68ch...swap%20019.jpg Next, here's a link of the newer 250 I put in the truck. Some holes were different - like the water temp sensor, etc. Is the hole in this pic? http://satellitehead.com/images/68ch...swap%20018.jpg
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
I tried to show the location of the hole in your pic, but your files are too large, and I can't compress them enough to post....but the hole is in the second ridge to the right, between the 2nd and 3rd bolts that hold on the pushrod covers
Questionable
mark it in one of these two smaller pictures - they should end up being small enough to post! (right-click the photo and "save as")
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 11-15-2005 at 06:00 PM. |
Done....any ideas?
Questionable
Not a clue. If they're threaded the same, My guess is simple: One would be used for a dummy gauge (which is shown being held in that picture) and the other for an real gauge w/needle (VDO?)
User #12137
![]() Join Date: Apr 2004
i got see if my 6 banger has it in a few mins
not sure if it matters, but the block was out of a nova from the information I have received.....not a truck.
User #12137
mine dont have it but i got a 6banger out of a 70 nove at my buddys house i will get pics of it too
heres a pic of the one here in my jimmy ![]() |
#13 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
The guy I bought it from took it out of a 77 nova......he said it was original to the car.
#15 | |
Resident Curmudgeon
#16 |
so basically thread a bolt in there to plug the hole (because it goes through the casting) and call it good?
Why would a bolt hole to secure a starter go through the casting? |
#17 |
Are the threads pipe (NPT) or bolt (SAE)?
The sender should be 1/8th in. pipe thread. A bolt will be 3/8th or 7/16ths. How deep is the hole? is it tapped into the journal so oil will come out, or just bottom out? |
