Old 11-18-2005, 08:38 PM   #1
KEH
Better late than never
KEH's Avatar
Clutch linkage squeak fix
I don't know about others, but my clutch linkage in the cab has always squeaked. Last weekend I eliminated the causes by replacing the clutch shaft bushings, which I ordered from LMC. They were easy to replace by working through the removed gauge cluster opening. I was surprised that the 35 year old bushings were not in too bad condition though.
The biggest improvement was installing a brass bushing on the clutch arm, where it connects to the pushrod that goes through the firewall. I bought a 3/8 ID brass bushing, cut it to length, and drilled out the arm hole to 1/2".
Shifting is now smooth and quite. This weekend I will do the same fix where the pushrod connects in the engine compartment.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 11-18-2005, 09:16 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Clutch linkage squeak fix
check that rod out real good mine as worn spot on the rod end like where it sits in the bracket
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 11-18-2005, 09:29 PM   #3
KEH
KEH's Avatar
Mine does too. I can't imagine why chevrolet built these without bushings there in the first place?
