Old 11-21-2005, 12:22 AM   #1
BowTieMan
BowTieMan's Avatar
drop blocks
I am thinking of making my own drop 3" drop blocks to run after I do my front disk brake swap with the drop spindles. What size square tubing should I use? I am going to box it in and all that so I know it will be strong.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 11-21-2005, 12:36 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: drop blocks
Thick wall tubing. At least .125 inch thickness is what I use.
By the way, the 3 inch block is going to make your u-bolts hang way below the scrub line. I don't know whether that bothers you or not.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-21-2005, 12:39 AM   #3
BowTieMan
BowTieMan's Avatar
Re: drop blocks
I'll have to look closer at it. I only use it from to and from school and work. And it will only be till I can get my rear springs. Maybe I will jsut go with some 2" or 2 1/2". So would it be 2"x3" square tubing to get a 2" drop?
Old 11-21-2005, 07:44 AM   #4
Tx Firefighter
Re: drop blocks
Here's a set I made awhile back out of 2x3 tubing.
Notice how low the u-bolt hangs below the wheel rim. And, those are 17 inch wheels. If the truck still had 15 inch wheels, it would be even worse.
