Old 11-21-2005, 04:50 PM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
rear disc conversion
Hey guys
I am sure there has been about a thousand threads on this.
I am not rich but would really like to do one of these since my rears are about shot anyway. I have done a ton of searching and have not come up with much. Is there a site or a write up on the parts etc to do this yourself? I do need the ebrake(just incase). Any info, other than some 500-700 dollar kit would be great. I would even consider changing rear ends if that was a more affordable option, plus i could use a little more width.
chevyguy_72 is offline   Reply With Quote
Old 11-21-2005, 05:43 PM   #2
roj2323
Re: rear disc conversion
http://steeltechsolutions.com/ how's $89 for the brackets? the rotors will run between 20-40 each and then depending on if you want a parking brake, calipers will run between $50-$300 loaded. i.e. they come with the pads.
ondrew
roj2323 is offline   Reply With Quote
Old 11-21-2005, 05:56 PM   #3
chevyguy_72
Vintage Evil
sweet that is definately an option are there any others?
Old 11-21-2005, 06:00 PM   #4
meathead95
computer illiterate
meathead95's Avatar
pm raggedjim he has done this and it is top notch
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-21-2005, 06:06 PM   #5
Hart_Rod
Hart_Rod's Avatar
Try to find a 94-96?? caprice/impala disc rearend (5 x 5 and correct width). You will have to weld on new axle saddles but that is probably the cheapest way to go. I think you can get a rearend for around $200 depending on gears and whether it is a posi unit. Axle saddle are probably less than $40.
R
Hart_Rod is offline   Reply With Quote
Old 11-21-2005, 06:11 PM   #6
john
member #16
john's Avatar
Heres another one. Probably not the cheapest but will give you an idea of what needs to be done. John
http://www.classicperform.com/tech_a...kes-trucks.htm
john is offline   Reply With Quote
Old 11-21-2005, 06:12 PM   #7
chevyguy_72
Vintage Evil
R
that is a great i idea. is there the connection for the panhard or do you have to get a kit of somesore for install other than the saddles.
Old 11-21-2005, 07:31 PM   #8
John Fabris
TOTY 2006
John Fabris's Avatar
Or heaven forbid, grab a factory Ford Nine inch from a Lincoln Continential that has rear disc brakes, buy an adjustable panhard bar with relocation brackets. the nine inch is 5 on 5 lug pattern...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 11-21-2005, 07:33 PM   #9
FormerMember
I thought that was 5 on 5.5" though?
FormerMember is offline   Reply With Quote
Old 11-21-2005, 07:50 PM   #10
ratrod67
ratrod67's Avatar
That's the kit I have on my truck. Worth it in my opinion.
ratrod67 is offline   Reply With Quote
Old 11-21-2005, 10:09 PM   #11
69TowRig
ondrew
Link no workee for me.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 11-21-2005, 10:17 PM   #12
72wascal
Hawaiian Member
72wascal's Avatar
I used a four 9 inch out of 66 truck and used Ford Racing (explorer design) brakes that gives the internal PB. I works well and stops on a dime. Like the versatility of using the 9 inch set up to swap gears. I had a lincoln rear with disc brakes but the rear end will not hold up well under serious horsepower.
72 C-10 ProStreet - 331 cu w/ T350 trans
9" shortened w/ disc brakes - Mild body modifications
3/5 drop - More in the works
72wascal is offline   Reply With Quote
Old 11-21-2005, 11:01 PM   #13
matt67350
matt67350's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=178840
Dennis did a great job on shis setup. Check it out!!!!
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 01-18-2006, 07:42 PM   #14
cell
Active Member
cell's Avatar
R
I'd like to go with rear discs, and I'd also like to change my rear end ratio to 3.08:1 on my 67 1/2 ton.
I am starting to think that it would be easiest and cheapest to simply swap out the entire rear axle assembly, instead of changing out the individual pieces. Also, this would mean newer parts, which means greater parts availability.
So, I think I'll lay out my options and bounce some ideas off of y'all.
Option 1: Get a complete rear end from a 94-96 Impala SS or Caprice w/police package.
Question: What about the rear sway bar? I currently have the kind which attaches to the differential housing, and the Impala/Caprice rear end's don't have 'em. Are there alternative anti-sway mechanisms I can steal from the Impala/Caprice donor car? Or can I have a machine shop weld on some sort of stud to which I can attach the sway bar on the new rear end?
(note for those of you considering this option - go sign up on impalassforum.com!)
Option 2: Change to a leaf spring rear end.
Is this even possible? Can I just get rid of the tracking arms, coil springs, and sway bar? Will the leaf spring based rear ends from the 73-87 or 73-91 trucks fit? (are they wide enough / too wide?) Will the leaf spring u-bolts attach to my frame correctly? Will I need to fabricate new points to attach the shock absorbers to the frame? And what about rear anti sway stuff?
Option 2 does seem to have the advatage of updating all my rear end parts to more modern stuff with INSANE parts availability, and it also seems like it would be easier to upgrade to higher bed / towing capacity this way (basically just need beefier leaf springs, right?). Also, I imagine a truck rear end will be heavier duty than an impala rear end.
Thanks for you input guys - y'all are an incredible resource!
cell is offline   Reply With Quote
Old 01-18-2006, 07:57 PM   #15
FormerMember
Could also use ECE's track bar re-location kit.
Old 01-18-2006, 08:26 PM   #16
67Mach1
67Mach1's Avatar
Jason my 67 GMC has leaf Spring Rear and I dont think I am going to be using my frame once I pull the body off of it for the short bed conversion I was planning....
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 01-18-2006, 09:20 PM   #17
cell
Active Member
cell's Avatar
67Mach1: Ohh, I'll have to come take a look at that!
Old 01-18-2006, 11:13 PM   #18
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Here is one I have saved because they also have kits for Dana 60's
http://www.blackbirdscustomtrucks.com/index.html
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 01-19-2006, 02:32 AM   #19
drink2mny
drink2mny's Avatar
Thanks Bill for posting us....
Your going to do what you want., but we are an option and on this board.
good luck in your ventures...
Support The Board
drink2mny is offline   Reply With Quote
Old 01-19-2006, 12:13 PM   #20
junkyardjohn
junkyardjohn's Avatar
I GOT ONE OUT OF A 76 LINKOLN VERSALLES. THEY ARE WITHIN AN INCH OVERALL, HAVE REAR DISCS & A PARKING BREAK, & ARE 5X5 LUGS. I DID A SWAP WITH A BUDDY OF MINE THAT OWNS A DRIVELINE SHOP. HE COMPLETELY REBUILT IT WITH ALL NEW BEARINGS & SEALS, CHANGED THE RING & PINION TO 355-1 GEAR RATIO & REBUILT A POSSI. THIRD MEMBER FOR IT. IT WAS LESS THAN $100 AT A LOCAL BONE YARD. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-19-2006, 02:18 PM   #21
cell
Active Member
cell's Avatar
thanks john, that's another potential source to add to my donor list!
Old 01-19-2006, 02:31 PM   #22
84 PUMPKIN
I've used this rearend in three trucks ('66, '67, '71) with great results.
84 PUMPKIN is offline   Reply With Quote
Old 01-19-2006, 10:09 PM   #23
hilljob26
hilljob26's Avatar
i sell the prints and templates to make your own brackets,mine use all 4 flange bolts instead of 3 like everyone elses,ive been selling them for 25 lately,let me know...mike
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 01-19-2006, 10:13 PM   #24
dennislbrooks
dennislbrooks's Avatar
$25 is a good price for a template. Does yours allow the re-use of the oem e-cable. Do they mount the calipers forward horizontal instead of top?
dennislbrooks is offline   Reply With Quote
Old 01-19-2006, 10:16 PM   #25
hilljob26
hilljob26's Avatar
well,there is an ebarke caliper to use,which should retrain your factory cable,the calipers mount straight up,but there is no difference as far as where the caliper mounts to the stopping power,trust me,ive tried about every angle out there,and these seemed to be the best,not only that,it made it easier for people to make there own,pm me for more...mike
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
