Old 11-22-2005, 01:05 AM   #1
shoobear
shoobear's Avatar
Frame questions
Ok, since im the new guy here, i have a few questions. Take it easy on me eh! Im sure the question has already been discussed in the past and will do a search after i post this. So, what frame will fit under a 67-72 LB 2wheel drive to make it a 4x4?I tried looking at the last frame post for frame measurements but the text was too small. Anybody done a swap?
cheers
I will run u over for FREE!!!
2001 F350 6" Lifted Dually
1970 ScoutII with chevy implants
1970 GMC 3/4 LB 4x4 (for sale)
1972 Chevy 3/4 LB 4x4 -project
shoobear is offline   Reply With Quote
Old 11-22-2005, 02:30 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: Frame questions
Welcome to the board from South Mississippi. With the right skills you can use a
73 and up frame under it, but it's not a bolt on and go deal.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-22-2005, 12:48 PM   #3
qksilver
Re: Frame questions
I have swapped a few later model frames under 55-59 trucks.
The later model 73- have very close to the same demensions.
The trick I have used to make it easier is to drill out the frame cab and core support brackets, after measuring (twice) their height and distance from the front axle centerline then mount them to the new frame. The width on the frames , I have found for 55-86 is close enough, the wheel bases with in an inch, made the difference up between the bed and cab.
Other wise you will have to deal with stuff that takes some time but isn't that hard;
Brake lines
fuel lines but I would try to use the saddle tanks from the later trucks, will work with some trimming of the cab (more room in cab)
Steering column linkage, no biggy, make sure it turns free and doesn't bind, between box and steering wheel.
not much wiring to deal with
Bumpers-
If automatic use a locktar linkage kit
Manual......don't know but I am sure stock stuff can work, watch out for lever ratios
It technically isn't hard but many small and a couple of large issues to deal with.
Steve
qksilver is offline   Reply With Quote
Old 11-22-2005, 11:48 PM   #4
shoobear
shoobear's Avatar
Re: Frame questions
hey thanks, im gonna grab my tape and head to the wreckers for some measurements!
cheers
