Old 09-04-2002, 11:52 AM   #1
gabet40
how big is your cam?
ive got a crane powermax cam and all the papers that give me that lift and durations, and loads and all that. but whats the one number that people use when tellin exactly what size it is, hence, how big of a difference it makes?
i dont think mine is too big, but the lift is 3027 intake and 3200 exhaust, with a rocker arm ratio of 1.5, advertised duration is 272? intake, and 284? exhuast.
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 09-04-2002, 12:04 PM   #2
Beast388
Suburbans RULE!
Beast388's Avatar
The most common way to talk the "cam talk" is by valve lift and duration at 0.050 lift. The valve lift is a constant number between cam manufacturers but the duration numbers can be different. Some companies rate the duration at 0.050 lift or 0.006 tappet lift. So that can make comparing cams a little difficult because they aren't using the same parameters.
But if someone were to ask how big your cam is, you would say: 0.454 Intake / 0.480 Exhaust lift with 272/284 advertised duration.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 09-04-2002, 02:53 PM   #3
Mike C
Mike C's Avatar
Beast is correct, but to clarify a little... Talk about cams duration at .050 tappet lift, but valve lift should be specified at zero lash for a hydraulic tappet and net lift if mechanical or the valve lash should be specified if quoting gross lift figures.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-04-2002, 11:08 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
My cam is about 2 feet long...give or take.
Old 09-04-2002, 11:27 PM   #5
Zkast
Zkast's Avatar
lol u goof! :p
Zkast is offline   Reply With Quote
