Old 11-21-2005, 10:11 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
72 blazer ign problem
I just picked up a 72 blazer and just got it running. The problem is the engine starts good when cold, but won't even fire when hot. Runs good, shut it off, no start. It has a 307 all stock, with point dist. and an auto tranny. Any ideas? I'm thinking coil, But would like some input. Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-21-2005, 11:26 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 72 blazer ign problem
Does it crank over at all... or just click?
Old 11-22-2005, 08:20 AM   #3
GMC AMI
GMC AMI's Avatar
Sounds like the coil and they are cheap to replace. A good starting point to start with. You may want to check the point wire connection. I had one that when warmed up was just loose enough to lose the fire to the points. The screw did not look loose but was my problem.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 11-22-2005, 12:21 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I had a problem with my '69 shutting off when it was hot. I would have to wait for it to cool a bit to get anything when I turned the key. It ended up being the plug into the back of the ignition melted. The ignition switch died and that killed the plug. I swapped out the plug and the switch and it was solved.
The switch in my '72 also died and it melted the plug into the back of it. I seems like it could be a weak point in the ignition system.
Look under the dash and see what shape the plug into the back of the switch is in. It might be a simple fix.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-22-2005, 06:54 PM   #5
too much stuff
Roadtrip!
Longhorn, cranks over fine except for a "hard" spot when cranking.
Bouncytruck, my 69 did the exact same thing this summer till i did the new ign switch.
mike, i will check the connections.
The truck is not dying on me, you can shut it off when it is running fine and then it won't start until its cold again.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 11-22-2005, 07:58 PM   #6
cdowns
cdowns's Avatar
a good way is to start out with a tune up// new plugs gapped correctly,new points gapped correctly,new condensor and rotor,new fuel air and oilfilters, new oil do all that then you're ready to set the timing// while you're under the hood is a good time to check for dryrotted vaccume hoses and brittle cracked dryrotted sparkplug wires and cracks in the dizzy cap also if vehicle has set for a spell you could put a quart of marvel mystery oil into 5gallons of new current gasoling/// most engines respond well to this type treatment alot of times it's cheaper in the long run to just do this basic stuff first
Old 11-22-2005, 08:04 PM   #7
truckdude239
truckdude239's Avatar
sounds like an coil put i'd go ahead and do an tune up while iwas at it
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-23-2005, 12:04 AM   #8
too much stuff
Roadtrip!
I started it up tonight with no problems, let it run about 2 minutes and shut it off. No start. Put my spark tester on the coil and have no spark. I am going to start with a coil tomorrow. I have done the oil change and the previous owner did points, plugs condensor and cap. It also has ALL new gas in it. If its not too cold i will update you guys tomorrow. Thanks.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 11-23-2005, 01:34 AM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Well thinking about this one I have an idea that the trouble may be in the wiring from the starter to the coil that delivers 12 volts to the coil during starting. It is connected to the outside terminal on the solenoid and is a yellow wire. I would try using a jumper from the battery positive to the coil positive the next time it won't start and have someone crank the engine to see if it will fire up.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-23-2005, 01:56 AM   #10
kwmech
Could also be the condensor. Just do a good old fashioned tune-up. OR now would be a good time for an HEI
Old 11-24-2005, 01:08 AM   #11
too much stuff
Roadtrip!
Well, i put a coil in and seems good so far. It is -10 degrees With wind chill right now so i didn't spend alot of time on it.
Hei will be the way to go, but i don't want to stick alot of time and $$$ into it until i can see how it will run.
Thanks for all the input. Eric
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 11-24-2005, 01:14 AM   #12
cableguy0
you can pick up a used hei for about 35 bucks. and it wont take more than an hour to do the swap. if you have replaced a distributor before. much more reliable easier starts and better mileage to boot
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
