Old 11-24-2005, 12:28 AM   #1
jku72
Shift pointer on tilt column broke
The pointer on my new-only-to-me tilt column is broke off. How in the heck can I change that little guy out? It's a '71 truck column.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 11-24-2005, 01:03 AM   #2
powell72
powell72's Avatar
Re: Shift pointer on tilt column broke
You need to take the indicator loose because the pointer clips under it and then the other end just slides into the groove on the column. That way the pointer can slide with the tilt movement.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 11-24-2005, 01:06 AM   #3
jku72
ahh, okay. I think I can get a needle nose plier on the end, it broke off down in there, but if it just slides out.....
Thanks for the info.
68 C10 burb
42 Willys MB
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
Old 11-24-2005, 01:31 AM   #4
powell72
powell72's Avatar
If the needle nose don't get it maybe you could screw a small screw into the plastic and pull.
Chris
