11-24-2005, 12:29 AM | #1 |
transfer case adapter question
Hey Guys
Its been a while since I messed with these older chevy trannys. I have a 79 chevy here with a 400 auto and full time case. The tranny is bad. I have a rebuilt 350 turbo that I want to put in it what do I need to find as far as a transfer case adapter? Thanks Don |
11-24-2005, 03:00 AM | #2 |
Re: transfer case adapter question
You'll need a TH350 to NP203 adapter. Really common so the cost at a bone yard won't be much. You might also call offroad design at 970-945-7777...stephen has lots of them i believe since a key ingrediant to his doubler is the forward section of a NP203. His web site should also have pictures of what your after.
Doug Wright
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
11-24-2005, 10:14 AM | #3 | |
Thanks I will check that out Don |
11-24-2005, 10:53 AM | #4 |
Need to change the input gear too. 350 is 27 spline, 400 is 32.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
11-24-2005, 12:25 PM | #5 |
If going thru all the changes, now would be a good time to upgrade the t-case to a 205.
