Old 09-04-2002, 10:05 AM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Belt squeal???
I have a bad belt squeal in my truck when I floor it some times. Its really annoying. I think its the power stearing pump belt and my thought was that when I flor it and the RPM go way up the pump cant spin at that high a speed so the belt slips. This was just one of my crazy ideas i thought of. I have no evidence to back this up. If anyone knows what the problem is or how to fix it that would be great. Oh and the belts are pritty new. I was thinking of converting to one serpentine belt but thats later on down the road. THanks guys.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 09-04-2002, 12:11 PM   #2
HotRod929
HotRod929's Avatar
Anyone?????
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 09-04-2002, 12:39 PM   #3
Blazer1970
Blazer1970's Avatar
Mine does it too, but I am 99% sure it is the slipping at the water pump pulley. Because of the Corvette water pump (larger pilot) I have on there, I had to go with a fan clutch that doesn't let the fan slip nearly as quick as the stock one. That combines with the fact that there is hardly any belt engagement with that pulley with the stock accessory bracket set-up in these trucks. I have to swap back to a normal water pump, and go back to the stock fan clutch.
Blazer1970 is offline   Reply With Quote
Old 09-04-2002, 12:55 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
To find out if it is a belt squealing, spray a shot of WD-40 or belt dressing on the v portion of the belt, best if you can do it with the engine running. If you use WD-40, the next step is to apply some belt dressing. I would try this one belt at a time until I found the offending belt. How's the pulley alignment?
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-04-2002, 01:17 PM   #5
HotRod929
HotRod929's Avatar
The pullys look pritty aligned to me.
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 09-04-2002, 02:25 PM   #6
HotRod929
HotRod929's Avatar
So just spray some WD-40 on the belts and the should stop squealing? Is that what you are saying Fred T?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 09-04-2002, 03:51 PM   #7
woodrow59
OzarkHillbilly in Atlanta
Had the same problem ,,,, mine was the alternator out of line. Have an '85 305 with '68 exhaust manifolds so things didn't match up just right. Had to bend the bracket that attaches to the manifold and magicly the squel went away.
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 09-04-2002, 04:21 PM   #8
COBALT
COBALT's Avatar
No, he's not saying WD-40 will stop the belt from slipping it will just stop it from squealing as a test to find out which belt is slipping. You should probably get someone to help you. Shoot the V with some WD-40 while someone's reving the engine. See if the squeal goes away. If it does then the belt you just sprayed is the problem.
Make sure they're as tight as they should be first of all. There's a deflection-per-foot figure that determines if the belt is tight enough (1/2" deflection per foot? 3/4"?--can't remember). I always do it by feel.
Another thing you can do is use a bar of soap. While the engine is running allow a bar of soap to rub against the V part of the belt until the entire belt has been dressed. That'll stop slippage as well.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 09-04-2002, 05:51 PM   #9
HotRod929
HotRod929's Avatar
Well so far i think its the powerstearing belt. Its pritty tight. Now what do I do?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 09-04-2002, 08:08 PM   #10
Zkast
Zkast's Avatar
Powersteering typically wont have much freewheeling resistance. Only when pressure is demanded, then it starts to drag.
"Most" of the time you'll find a waterpump pulley causing the noise, due to a seized fan clutch or loose belt. Assuming you have a belt driven fan? it can cause a massive load at higher rpms making the belt slip(squeal)
If you arent positive on the belt tension you can try removing one belt at a time, run it and find the one... but thats alot of work.
I'm not ruling out a P/S pump problem but the more common is the waterpump/alternator belt.
The WD-40 is a good tip for finding the belt noise, its not meant for a fix... just a means of finding out which one. Belt dressing is a mess after its been on a little while. Clean belts and pulleys dont make noise... find out WHY its making noise.
Good luck with it.
Zkast is offline   Reply With Quote
Old 09-04-2002, 08:16 PM   #11
HotRod929
HotRod929's Avatar
Well I tried the WD-40 thing and it got me no where. I sprayed it on the 1st belt (PS) while it was running and reved the engine. Squeal. Sprayed it on the alternator and waterpump belt. Same thing squeal. I noticed that maybe my PS pully was wobeling a little. It might have been my mind playing tricks on me. So im stuck again.
How do I test if my fan clutch is stuck?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 09-04-2002, 08:38 PM   #12
Zkast
Zkast's Avatar
Warm the engine then turn it off. You should be able to spin the fan NO MORE than 1.5 revolutions. If it turns more than that its bad. If you cant turn it at all, its bad.
In your case, I would remove the outside belt then rev the engine. If the noise is still there remove the other belt. This will let you know if there is a problem with a belt driven componant.
Bad belts will do this and drive you crazy lol. The belt looks good but the cords have seperated which gives no tension. You can adjust it all day long and it will just act as a rubber band.
Try popping the belts off and give that a shot.
Old 09-04-2002, 08:50 PM   #13
HotRod929
HotRod929's Avatar
Well i know how to get the alternator belt off but how in the world do you get the Power Stearing belt off? Do you have to take off the PS pully? Is it hard?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 09-04-2002, 08:56 PM   #14
Zkast
Zkast's Avatar
Try taking the alternator belt off first. I'm willing to bet you find your problem there.
Old 09-05-2002, 12:16 AM   #15
Gee_Emm
I had this problem too and it drove me nuts!!!!!!! I tried everything, I thought it might be the bearings, I did the WD40 thing, i tried playing with the aligment of the accesories, finally one day I decided I will put on the spare belt I had in my truck. I havent heard a peep since the day I changed it.
Gee_Emm is offline   Reply With Quote
Old 09-05-2002, 12:21 AM   #16
HotRod929
HotRod929's Avatar
Which belt did you replace? The PS belt or the water pump/alternator belt? And how do you get the PS belt off? Do you have to take the PS pully off or what? THanks for the help Gee_Emm. I might try that tomarrow.
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 09-05-2002, 12:38 AM   #17
Gee_Emm
It was the altenator belt, I determined it with the WD40 method. I think I did take the pulley off the ps pump, my memory is a little fuzzy on that. I know how annoying this noise is, it was sooooo embarassing. At one point I was even thinking my harmonic balancer was coming apart. I spent hours trying to figure that damn noise out when in the end the fix was so simple. Actually more is coming back to me now, I just remember that the reason that I was having a problem was that the belt that was on there was too small, the one I replaced it with was wider. Yah that makes sence, the belt being too small was sitting down in the pulley too deep and thus was rubbing against the edge. Geez fuzzy memory here, the bad part was all this only happened about a year ago :p :p :p
Old 09-05-2002, 12:44 AM   #18
Gee_Emm
Oh and about the ps pump pulley, those things are a major pain in the ass to take off, I think i might have unbolted the whole pump from the bracket and left the pulley on the pump.
Anyways thats what I would recommend doing cuz you can easily mess that pulley up getting it off.
Old 09-05-2002, 01:08 AM   #19
HotRod929
HotRod929's Avatar
So you think i might need to go with a slightly wider belt for the water pump/alternator Gee_Emm? Sounds like thats worth a try.
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 09-05-2002, 01:11 AM   #20
Gee_Emm
Yup hidden in all my rambling was that suggestion. I don't know what size is supposed to be on it. Maybe someone on here knows that?
Old 09-05-2002, 01:30 AM   #21
HotRod929
HotRod929's Avatar
Yea anyone know what size the belts are suposed to be?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 09-05-2002, 07:12 AM   #22
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
You asked several times about how to get the belt off of the P/S pump, and the suggestion was to take the pulley off. I don't think that is right. For one thing (think about this), when you put the new belt on, and you have to get the pulley back onto the shaft, along with the nut that holds it on AND you have to figure out how to hold the shaft while you tighten the nut.....well, let's just say that you will be extremely mad at yourself for taking that route. It is NOT the way to go.
There is an adjustment on the pump. It may not be easy to get to, and it is probably covered in an oily, dirty layer or two, but it is there and it is meant to be used when you have to adjust/replace the belt.
Here is what is written in my shop manual:
1. Loosen nut on pivot bolt and pump brace adjusting nut.
CAUTION: Do not move pump by prying against reservoir or by pulling on filler neck.
2. Move pump, with belt in place until is belt is tensioned to specifications (using a belt tension tester).
3. Tighten pump brace adjusting nut. Then, tighted pivot bolt nut.
So, there are TWO nuts to loosen, and neither one is the nut that holds the pulley on. You may have to get under the truck. You may have to get a good flashlight, or drop light, to see it. But, you'll be glad you did. It won't be easy, but it is way easier than pulling the pulley off of the pump. After all, the pump is designed for replacement. Removing the pulley won't do diddly for getting the pump off of the engine. That's why there are those two bolts mentioned above....the pivot bolt and the pump brace bolt.
Hope this helps someone.
Member Nr. 2770
Old 09-05-2002, 07:55 AM   #23
Huck
Huck's Avatar
Belt squeal is best fixed with a new belt--period. The old ones get brittle and hard without being visable. There is a new style belt out that has notches in the top of the belt that helps bite into the pully to prevent slippage. It's called "Top Cog" made by DAYCO. Try call ing some of your local auto parts stores like Advance Auto Parts, PEP Boys, etc. Each belt has a tension adjustment that does not require component removal so look for it. More then likely, if one belt is squealing, the others are also likely candidates for replacement. I like to bring the old one with me to the store to ensure correct length and WIDTH as it makes a difference. I'v got a squealler on a recent truck purchas I made and will be replacing all three belts shortly and while I'm at it, checking the radiator & heater hoses in the process. Once I'm in there, I like to take care of the cheapie stuff all at once---loosing 2 gallons of antifreeze in the middle of winter is not my idea of fun. MY .02 ----good luck---Huck
Huck is offline   Reply With Quote
