Roll pan, license lights, 67 LWB
I installed a roll pan years ago and can't remember what brand it is, I
THINK it's a Sir Michaels but I'm not sure. I need the two license plate lights for it, the holes in the roll pan are "D" shaped, do any of you know where I can get these? Thanks Ron
'69 SWB '76 International "Terra" "Hooked on holiday beer" |
laying low
![]() Join Date: Mar 2001
Re: Roll pan, license lights, 67 LWB
Most any of your parts stores that have replacement lamps like tail, turn, backup, etc, should have what you need or one that sells bumpers should have them also.
#3 | |
Truck Parts Mfg.
![]() Join Date: Jul 2005
Ron, that is an older Mar-K pan. The tag lites are still in stock, part number 100865. Try this link to the catalog pdf http://www.mar-k.com/rear_pans.pdf . I sometimes have trouble with the link but hopefully it will work. If not just check the partnumber on our online catalog.
Mar-Ktech
GET MAR-K Quality! Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks |
#5 | |
link works, this is what he was mentioning.
I have (or had) a pair that I am not using. I will see if I can find them tomoorow.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#8 | |
Truck Parts Mfg.
Ron: Sorry to be a little slow to respond. Busy doing holiday things. Yes they fit the D hole. You should have a D shaped hole and two small holes beside the D and positioned forward from the D, and spaced a couple inches apart. Those are for the screws that hold the tag light. The tag light has a light socket that extends into the D opening and there is a locating pin molded to the back side of the tag light bezel that fits into either the upper or lower corner of the D opening. You might have to trim a little from the opening that has been cut into the rear sill to get the light sockets to fit. I don't have those drawings here with me. The D opening is completely covered by the tag lights.
These are nice tag lights, and come complete with the light socket, bulbs, and mounting screws. Most people didn't want to pay the extra or wanted to use their own lights or a lighted tag frame so we phased out that system. Its still available for customers that want it. I will ask our webmaster to look at that link. It definitely does not work on my system but does on others.
Thanks, I'll order tomorrow.
