Old 09-04-2002, 03:39 PM   #1
wlee
Just an Old Mr Goodwrench
Compression Ratio Chart
Here's a quick easy way to figure compression ratio on small block Chevy engines
1969 CST 20 Longhorn
1970 CST 20 Fleetside
1991 Jaguar Sovereign
1992 Mazda Miata
wlee is offline   Reply With Quote
Old 09-04-2002, 04:00 PM   #2
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Man wlee, you are awesome, i was just looking for this exact thing last nite! i just got a copy of desktop dyno off a friend and was trying to figure out my numbers!
thank you very much
Benson
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 09-04-2002, 07:03 PM   #3
Beast388
Suburbans RULE!
Beast388's Avatar
I would only use that to get a very very rough guestimate of comp. ratio. It doesn't take into account variences in valve relief volume, head gasket volume, true head cc, and deck height etc.
There are too many different gaskets, pistons, heads and deck heights for that to be very accurate.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 09-05-2002, 10:33 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
too many differences indeed, there were a couple different 305 engine pistons used, the L69 ones are alot different than the LG4 ones and then there were different CR;'s of 350's throughout the years, 8.5, 8.6 and 8.2 etc etc.
then the head gasket deal, some thinner some thicker, replacement composite ones being thicker than factory steel ones., and so forth,,
Fast68Chevy is offline   Reply With Quote
Old 09-06-2002, 09:00 AM   #5
JimKshortstep4x4
Smile
Thanks for posting this chart. It certainly is helpful for deciding basic head volumes needed for small block engines for particular compression ratios. Variances or other factors can be addressed
for the particular engine, but this gives a great starting point.
Jim
