Old 11-29-2005, 01:39 PM   #1
boatpuller
boatpuller's Avatar
Cool is my rear positive?
anyway to tell from vin# or build code if it has posi or not?it was originally a diesel.i guess i could do it the old fashioned way 1 black stripe or two?the diesel has been yanked and an 90 iroc 350 is in it's place.so it likes to lay it down on occasion.
boatpuller is offline   Reply With Quote
Old 11-29-2005, 01:47 PM   #2
DrPepper
Re: is my rear positive?
Black stripes are fun, but you can find out for less. Jack the rear up so both tires are off the ground. Rotate one tire. If the other tire turns the same direction, you have a 'positive rear'. If the other tire rotates the opposit direction, you have an 'open rear'.
BTW, the way your question is stated could lead to real interesting responses. But I guess you already knew that.
DrPepper is offline   Reply With Quote
Old 11-29-2005, 02:38 PM   #3
boatpuller
boatpuller's Avatar
no..no..no i'm a happily MARRIED man.to a beautiful woman{anymore you have to clarify that too i guess} i'm just bored here in the pouring down rain.thought somebody had a diesel that may of had posi or there was an vin code that let you know.also trying to trace cab leaks in the rain,but thats another post.
Old 11-29-2005, 05:03 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
G80 will be listed in the options sheet in the glove box. If the limited slip is worn out, the above method doesn't work.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-29-2005, 07:54 PM   #5
SlapFish
Real Men Wear Orange
If you can find the code but not the description for some reason, GU4 is the 3.08 non-posi.
SlapFish is offline   Reply With Quote
Old 11-30-2005, 01:23 AM   #6
jimfulco
Peg-legs can leave two stripes if the tires are loaded just right.
jimfulco is offline   Reply With Quote
