Door locking procedure
Can someone describe the procedure to lock the doors on a 72 GMC pickup, I have tried everything and cant get them to lock, close as I can come is turning the key with the door closed and it locks but after I remove the key you can unlock the door by opening it normally heh
Thanks in advance |
You may need to adjust the key mechanism,you will need to remove the door panel and look inside and see what is going on there,Is this the same on both doors?I have to shut my door and lock it with the key,Is your key mech. lined straight up and down?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
Re: Door locking procedure
Not really sure I got my kid messing with it right now I will take a closer look at it tomorrow, I had him remove the door covers so we could lube things up good in the doors the window was getting stiff and the lock was stiff.
So normally to lock you close the door then use the key to lock it? You dont push the lock down then hold in the thumb as you shut the door? Thanks again guys. |
God Bless Mr. T
I also have to close my door and lock it with the key.
Like a midget at a urinal...sometimes you must stay on your toes. |
#5 | |
I am pretty sure this is how all of them are set up... took me a long time to get used to it popping up if I just pressed the button.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over. _______________________ 2006 VW GTI |
in my '67 I have to close the doors then lock them with the key aswell.
its all about the +6 inches
they are all like that.
Its Magically Delicious
fail safe method to prevent you from ever locking your keys in the truck
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
![]() Join Date: Nov 2003
Try pushing on the door as you turn the key. I have one side where the weatherstripping still pushes out on the door, and I have to push on the door when I turn the key to lock it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
One key and this "key in door" locking proceedure prevent lock-outs.It`s not that people are smarter,now.(obviously the opposite).But,all the revenue gained for locksmiths and the chance to offer a satelite system to help you in your vehicle would be lost.Can`t have that!
I had to get used to not putting the key in the door to lock it.Someone had to show me to just push in the button.Now,can someone explain how I can get my horn to honk when i hold my fob up and squeeze it?
#11 | |
#12 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#13 | |
Ok then whats the problem that you have to push in the door to make it lock their must be a adjustment you can make? Thanks for the help I will work on it some more. |
![]() Join Date: Jan 2005
My passenger door is the same. I turn the key and it seems to click, but really doesn't. I have to almost bend the key to get it the rest of the way to finally make the sound of the locking. Plan on lubing the lock and mechanism and see if that helps.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
#15 | |
I lubed everything inside the door up really well things do move much easier. |
#16 |
No,I DON'T have Tourett's
Door lock sets are what.........$25?
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
#17 | |
#18 |
A.K.A- Crummy
Had one truck you could lift up on the door and it would work fine for a while. Weak behind the hinge.
2003 Silverado Z71 Are fishermen all liars? Last edited by 1969 C/K CST; 12-01-2005 at 02:21 PM. |
#19 |
Keep On Truckin'
I had the same problem with mine. You go to lock the door with the key (they are all like that as mentioned) but the lock button won't pull down far enough to actually lock the door. But, if you try the same process with the door open the lock works. After dinking around with mine awhile we figured out the little star wheel on the door that engages the latch mechanism on the door jamb created a wear pattern on the same teeth after 30+ years of opening and closing. The door lock star wheel simply toggles back and forth on the same teeth it doesn't rotate to the next tooth everytime the door is opened or closed. I believe there are six or eight teeth on the door side lock wheel. With the door open, push the button in on the door handle on the outside and rotate the star wheel one notch, close the door and try to lock the door with the key. Repeat this process until it locks with the key. This allows you to get the original wear pattern back in line between the door striker and the door latch.
I hope this works for you like it did me....
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
#20 | |
Sounds good I will give it a try, I also have a 86 Suburban thats locks work perfect wonder if they will work in my 72 doors? The burb also has power locks has anybody rigged up power locks in their older trucks ? Thansk again. |
#21 |
Great info mocwon, I will have to try that myself.
#22 |
Had the same problem on my son's (orangeuavol) Blazer. Worn part in latch it's self. Fix --weld worn part and grind back to orginal shape-cost-a little time.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#23 |
Is there any way to change stuff around so I can just push the knob down and it will stay locked even after I close it?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
#24 |
Nope.
#25 |
Water gettin`inside the door over the years can make the sliders a little crusty.They can use a little scuffing up then grease.
