12-01-2005, 07:52 PM | #1 |
Active Member
My engine stand came in
I ordered an engine stand from JC Whitney, and it recently came in. I had to run to Lowe's to get some additional washers (the ones supplied were too small and/or too few).
More details are over in my blog post. Last edited by cell; 12-01-2005 at 08:15 PM. |
12-01-2005, 08:11 PM | #2 |
Re: My engine stand came in
What size of engine are you using your stand for ? just curious .... Joe
69 Chev C-10 ... painted and ready to reassemble ( for sale ) 82 Custom Deluxe ( have parts to restore ) Last edited by junkyarddog1956; 12-01-2005 at 08:18 PM. |
12-01-2005, 08:14 PM | #3 |
Active Member
12-02-2005, 05:11 AM | #4 |
Just be careful. If engine not postioned right, those 3 legged stands can fall over. Hate to be a bummer. Have seen it happen. That's why I used a 4 legged stand. Just my $.02.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
12-02-2005, 02:06 PM | #5 |
Questionable
Ditto. I got a 1-ton stand, fold-up with four legs and five support wheels. That thing was about bent over from the weight of my inlines. Be very careful. Before you unbolt the engine from the cherry picker, loosen up the slack enough that it won't hit the floor if something breaks, then be sure to bounce it up and down on that stand a couple times really good to make sure the stand ain't gonna snap.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
12-02-2005, 02:07 PM | #6 | |
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-02-2005, 05:24 PM | #7 |
I also had a 3 wheeled engine stand tip over on me, lost the power steering pump & pulley. I was thinking of modifying mine and making it a 4wheeler. Has anyone done this before ???
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
12-02-2005, 05:28 PM | #8 | |
Not hard to do Gary. Then again, you can borrow mine if you like. I am done with motors for a while. |
12-02-2005, 05:30 PM | #9 |
Active Member
wow, this sounds like a pretty common problem. perhaps I should have gone with the stand with 4 wheels. Maybe I can rig up some extra supports with 2x4's.
Thanks for the advice everyone. |
12-02-2005, 05:36 PM | #10 |
~Rest In Peace~
you'll be fine just make sure your lube the wheels
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
