Old 09-07-2002, 10:35 PM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
Body lift pros and cons?
I've ordered springs with a 2" lift and am wanting to go higher. I know that 2" is the max on the suspension, so I've started considering a body lift. What are the pros and cons of body lifts? How difficult are they to put on? Anyone with picks of their trucks maybe with just a body lift?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 09-08-2002, 12:18 AM   #2
Blue_71
Bloo
Blue_71's Avatar
pros: cheap easy way to lift
cons: big gap between frame and body, pretty sure it lets th ebody move around more
only thing i can think of off the top of my head
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 09-08-2002, 10:31 AM   #3
6869704X4
I got a 2in lift. Happy with it. Biggest prob might be bumpers. Ive got my front bumper temp installed in the stock position.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 09-08-2002, 11:46 AM   #4
Tink
Tink's Avatar
Body lifts are much cheaper and usually easier to install. The biggest con is the gapage between body and frame... which is mostly noticable with the bumpers and the box. You could cut pieces of rubber to cover up the gapage with the box and buy (if avalible) or fabricate bumper relocation brackets for the gapage with the bumpers.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 09-08-2002, 04:27 PM   #5
sakohntr
sakohntr's Avatar
body lift
Body lifts make things alot easier to work on but i dont care for the gap. Try using a spacer block between the axles and springs, that way it wont affect your bumpers, no gap and you still are going up. Try some 2 inch spacers out of a late model 1/2 ton chevy which are made from cast iron and are the correct width. You could also just use hockey pucks or some teflon stock to go up an inch or so. Dont forget you will have to cut up your fan shroud if you body lift. good luck
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 09-08-2002, 04:50 PM   #6
Slick71
Slick71's Avatar
bigcarguy,
Why is 2" the max on suspension?
I ordered 4" springs and put blocks and an add-a-leaf in the rear to level things out and am running 33" tires. Body lifts are O.k, but the only thing you're gaining is a higher body and ability to put on bigger tires. If you want increased travel, spring lift is the best way to go. It all depends on what your gonna use your truck for.
You asked about installation of body lifts? They are very easy to install and can be done in an afternoon with a couple of friends who have good backs. I agree with the others about lifting the bumpers and covering the body gap. If you do go with a body lift, it looks best to cover that gap up.
1972 Chevy Blazer 4X4
Savannah, MO.
www.thefarmatadair.com
Slick71 is offline   Reply With Quote
Old 09-08-2002, 05:18 PM   #7
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Slick71, I think he's talking about a 2 wheel drive.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 09-08-2002, 06:57 PM   #8
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
yep, 2wd with coils all around. I've been told that I can only go 2" on the front without modification or else the ball joints will be at a bad angle.
Old 09-10-2002, 12:19 PM   #9
chevroletrucks
Had an 88 k1500 with a body lift,I would not recommend it unless thats your last option. You lose alot of body control,feels funny etc. but, if the sky is what your after...go for it!
67' Chevy C10 Lwb small rear window
71' Gmc 1500 custom 4x4
72' Gmc Grande Sierra
chevroletrucks is offline   Reply With Quote
