Old 12-02-2005, 04:34 PM   #1
matapalo
Swing away spare tire carrier for burb?
I was wondering if anyone has tried to mount a swing-away spare tire carrier on the back of a '67 - '72 suburban with enough clearance for barn doors. After a pretty good search on the net, it doesn't seem like there are to many options out there.
Here are a couple things that I did find:
http://www.kenmtn.com/html/multi-carrier.asp (don't know if they make this to fit a '67 - '72 burb and it is very expensive at around $600+)
http://www.rockstomper.com/catalog/pieces/hinge.htm (This might be a good start for making a custom carrier, but then you'd have to fabricate the rest?)
My current setup has the spare mounted in a cage on the roof. It works, but I'm getting a little old to be doing the clean & jerk with a 35" tire and wheel every time I want get at my spare.
If anyone has any ideas of how to get my spare mounted on the back of my burb, please share!
1972 3/4 ton 4x4 Suburban
1978 Chevy Luv
1967 Ford Mustang Conv
matapalo is offline   Reply With Quote
Old 12-02-2005, 05:10 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Swing away spare tire carrier for burb?
You could try a factory swing away from a Blazer 69-72 or even a 73 and up? Good luck.
70rs/ss is offline   Reply With Quote
Old 12-03-2005, 07:28 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
BobbyK made a nice swing away for his Blazer. It hinges on the bumper.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-03-2005, 09:58 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Check out some of the 4X4 mags and also look at Blazers,Bronco's,ect.I have seen one mounted on a Panel that was off something else.It had to be slightly modified and bolted to the original hinges.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-04-2005, 03:08 PM   #5
matapalo
Thanks for all the replies and ideas! I think that it's high time that I begin scouring all of the wrecking yards in the Bay Area and search for different carrier options, starting with older blazers.
I'll post pics when/if I ever get it together.
1978 Chevy Luv
Old 12-04-2005, 08:10 PM   #6
bouncytruck
SKINNY TIRES RULE!
Your probably going to have a hard time finding swing aways from a first gen blazer in a wrecking yard. If you do find one, don't forget to pull the brackets that are up inside the bed between the inner and outer skin. The top one usually has a long rod attached to it to get it up into place. You will probably need to pull the tail light to get it. I'm not sure if the second generation blazers had the same mouning method.
bouncytruck 1972 K5
Old 12-05-2005, 09:52 AM   #7
smokekiki
Mike
smokekiki's Avatar
The only problem with a first gen blazer carrier is the blazers rear is square and the suburban slopes.The bumper mounts look like the best option,if You don't want to run the stock bumper.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 12-06-2005, 07:36 AM   #8
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
My swing-a-way tire carrier is mounted to my aftermarket bumper.
If you run a stock bumper you could easily make a bracket that would run on the backside of the bumper and attach what-ever type tire carrier to that.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-08-2005, 03:29 PM   #9
matapalo
Made a day trip to all the wrecking yards around Sacramento and the SF Bay Area yesterday. Diddn't find much.
Lots of things that bolt directly to the rear door, tailgate or door hinges of vehicles. Unfortunately not made for the weight of a 35" spare.
Lots of things that mount to the truck body above and below the rear tail light like the first gen blazers. But like Mike said, these fit to the rear contour of the vehicle and the back of the suburban is unique.
I love what BobbyK did for his blazer. Thanks for posting the step by step in the FOTKI gallery. That's the kind of info you can't get anywhere else and a clear illustration of why this forum is such an invaluable asset to it's members. I'll be sure to leave plenty of clearance for the rear tail light if I try fabricating one for myself though
1978 Chevy Luv
Old 12-08-2005, 08:07 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-15-2005, 08:06 PM   #11
Burb
Coordinator of Synchronicity
Burb's Avatar
I just recently bought a swing unit from a F*#@ junkyard, '89 Bronco I believe, and I'm in the process of making some new mounting hardware to mount to my Burban's fender, 3/4 ton 16" A/T wheels just don't drop in the spare tire hole very well. I have a lift hatch-tail gate though... but the swing should clear for yours, just look a bit strange...level wise.
Just an option...
Burb is offline   Reply With Quote
Old 12-21-2005, 12:34 AM   #12
86swb
Born a Chevy Man
86swb's Avatar
Hey BobbyK, that looks like a great set up.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
