Old 12-05-2005, 05:43 PM   #1
BOSS
Just here to help
BOSS's Avatar
More brake help please
Hey guys,i have had some trouble with my brakes and i though i could fix it but i guess i was wrong.lol.first i will let you know what it has been doing.When i push on the pedal sometimes it is like i have no assist most of the time,even when i pump the brakes i just get power brakes some of the time,now for what i have done,i have a new booster that does work because when i pull the vac hose off of it i can hear it release the air inside,also i have put new pads on the front.any other ideas i can try to get them to work like they should?what else would you suggest?Thanx for any help i can get!!
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 12-05-2005, 05:47 PM   #2
truckdude239
truckdude239's Avatar
Re: More brake help please
i'd check the check vavle on the booster sounds like its sticking
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-05-2005, 05:51 PM   #3
BOSS
Just here to help
BOSS's Avatar
where is that located at exactly...lol.
Support our site
Norwood Survivor
Old 12-05-2005, 06:21 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Has your truck always had power brakes, or did you add them yourself.... is it possible you hooked up the the wrong vacuum port?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-05-2005, 06:29 PM   #5
BOSS
Just here to help
BOSS's Avatar
as far as i know it has allways had them,it didnt have an engine when i bought it but i got the vac hooked up to the back of the carb.
Support our site
Norwood Survivor
Old 12-05-2005, 06:33 PM   #6
67ChevyRedneck
You could have a bad carb or bad booster? I'm guessing when you pull the hose with the engine running you can hear it constantly sucking air? Your saying your brakes work, but you have no power assist, right? maybe your new booster is bad?
Jesse James
Project "On a Dime"
Old 12-05-2005, 07:26 PM   #7
dwaite72lnghrn
A question? Did you pull the check valve out of the booster or just the hose? On mine when I pull the check valve it slaps real hard like a spring snapping. If I pull the hose no sound.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 12-05-2005, 07:38 PM   #8
BOSS
Just here to help
BOSS's Avatar
i pulled the valve out and it poped,is there somewhere else i can try to attach the vac line to besides the carb?I have another carb i can try if i need to,thanx for all of the help so far.
Support our site
Norwood Survivor
Old 12-05-2005, 07:41 PM   #9
truckdude239
the vac line for the power brakes should not be hooked to the carb but to the intake manifold you get more vac from the intake and makes the brakes work better
David fuller
2000 Tahoe 5.3l 378
Old 12-05-2005, 07:45 PM   #10
BOSS
Just here to help
BOSS's Avatar
that may make a difference,i will have to see where i can put it at,it is the rpm performer edlebrock,any ideas?
Support our site
Norwood Survivor
Old 12-05-2005, 08:03 PM   #11
dwaite72lnghrn
Every vacuum booster I ever saw was in the back of the carb it is the same as the manifold. Do you have a vacuum gauge you could put on it to see if the hose is good. Most have a metal tube from the carb to just above the valve covers then change to rubber to the check valve. It is a very stiff hose so it won't collapse with the vacuum.
2009 HHR aqua blue
Dave & Jeanne
Old 12-06-2005, 07:05 AM   #12
BOSS
Just here to help
BOSS's Avatar
sorry i dont have a gauge,any other ways to check it?
Support our site
Norwood Survivor
Old 12-06-2005, 07:26 AM   #13
dwaite72lnghrn
No accurate way. Pull the hose and put your finger over it start the truck and see if it pulls on your finger then after it is running take your finger off and see if the engine stumbles or dies. If the hose collapses it will stay running smooth. this should be done when the engine is warmed up.
2009 HHR aqua blue
Dave & Jeanne
