16.5 inch trim rings?
Does anyone have any 16.5 inch wheel trim rings or know where i could get some?
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
CP, The 16.5" wheel was a size used on the 3/4 ton and up HD work trucks. Trim rings were not an option.
I know of no aftermarket supplier either. Sorry. Maybe you would like to switch to a 16" wheel?? |
its all about the +6 inches
While I have yet to try this, I hav been told that rings from a 16 inch will fit.
Thanks for the info. I don't think illbe switching to 16s because i got the 16.5s off my engine donor truck to replace my 16" split rims.
If I'm not mistaken, I saw the trim rings you want in a J.C. Whitney catalog?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
also good luck fidding any replacement 16.5" tires without spending $$$$$$
i assume this is on a 3/4 or 1 ton, if you were closer id give you set of five std one piece 16" wheels for cheap that i dont need, and the tires on them are all nice and awesome tread. i think 265/85/16 size good luck. |
damn...if I was closer I'd be interested in those...
