12-07-2005, 06:57 AM | #1 |
GMC Dreamer
Rear spring lowering info
Just wonderin how much of the coil I have to cut to get about 2 in. lower in the rear.
12-07-2005, 08:13 AM | #2 |
67-72 Addict!
Re: Rear spring lowering info
You can't cut rear springs.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-07-2005, 09:16 AM | #3 |
Fabricate till you "puke"
If all you want is a 2" drop, a 2" set of blocks & longer U bolts should do the trick....... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-07-2005, 01:28 PM | #4 |
Outlandish Trends - FL
Just buy some lowering springs and be done w/ it. They're only $100. Check out Early Classic, McGaughy's, or CPP. They all have quality stuff. You can't cut the rear springs like the fronts since the springs are tapered on each end. You wound't be able to fit the spring into the mounting plate if you cut them.
-Bret 67 short-fleet sold! |
