Old 09-02-2002, 10:53 PM   #1
chevyman 68 C/10
chevyman 68 C/10's Avatar
does it matter witch direction the sway bar is mounted
On the rear of a coil spring truck why if at all would it matter if the sway bar was mounted going to the front or rear of the truck as long as the bar is mounted firm on the rear end and to the framewith proper bushings and no bind.
Would this in some way I can not figure effect the operation? If not I have a bar that I want to mount to the rear end and rearward toward the back of the frame.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 09-08-2002, 02:47 AM   #2
Fast68Chevy
Fast68Chevy's Avatar
in all actuality, it wouldnt really matte,r as long as the ends of th bar each cntact somewhere on axle tubes or to a part near them thats attached to axle tubes, closer to the axle tubes then the better off you will be,.
when you go around a turn fast the truck leans and preloades the end of the bar thats in the inside of the turn and twists the entire bar creating even more preload(reisistance) and thats what keeps truck more level and creates the effect of anti sway.
good luck
Fast68Chevy is offline   Reply With Quote
Old 09-09-2002, 11:02 AM   #3
chevyman 68 C/10
And how Fast68Chevy I have already installed it. I think it is really a vette disguised as a great Chevy truck. IT really handles around the corners. I can not wait to get 17's and better tires on it.
