Lift Springs
Where can I get 2" lift springs for a 2wd half ton?
fronts or rear, you didn't say. If it's the fronts you can use BB sprigs if you have a SBC. 2 inches is the max you can go becuse of ball joint angle limit. It's going to be very stiff up front. For the back, your guess is as good as mine. I run a spacer on the frame side
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
Fabtech, Rancho and JC Whitney should all be able to help you out.
Finally a Bulldawg
If you've got coil springs front and back like me, then you can get 2" lift springs from Eaton Springs. I ordered mine last week and they should be coming by the end of this week. Mickey's a really nice guy and can answer any questions you need. His site is www.eatonsprings.com .
Ah yes, the college life. School all morning, work all night, study when ya can. Uh... ![]() |
