Old 12-16-2005, 09:44 PM   #1
69TowRig
Re: MOTORHEADS--69' 307ci tell me about it...
Originally Posted by 409biscayne
If it was me i'd tuck the 307 away in a corner of the shop , and buy the best crate 350 i could afford , that way you have nice power in the truck and still have the original mill if you ever need it . I don't ever see anyone mention it , but we always used Pertronix Ignitor ignition , fits under the cap on your gm distributor ,eliminates points and keeps it looking original . There only about $75 and a quick install
Jeg's dropped the price on their NEW HEI distributor with cap and coil to $90:
http://www.jegs.com/webapp/wcs/store...tegoryId=26203
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 12-17-2005, 02:17 AM   #2
mark69k20
mark69k20's Avatar
This unit will bolt in and replace origional points and condenser any special installation "skills" required, I cant seem to figure out what HEI is, thought it ment high energy ignition but then i seen someone installed an HEI intake... help me out whats it stand for???
mark69k20 is offline   Reply With Quote
Old 12-17-2005, 11:22 AM   #3
69TowRig
Easy. The HEI distributor is larger in diameter than a standard one, so some large intake manifolds do not fit. I have not done it myself, but I do not believe on these vintage trucks running stock manifolds that this is a problem. Why they are called "HEI manifolds" I guess has to do with making things quick to understand. You have the acronym right.
